LS-1 Edit or Ed Wright??
Old Sep 15, 2003 | 08:26 AM
MikeyD's Avatar
MikeyD
Default LS-1 Edit or Ed Wright??
The dilemma: I have recently swapped out the rear and Torque converter as well as tranny. Went from 2.73 to 3.15 and a Yank 3000 TC. Started getting the dredded 1870 code. Consensus is that programming will fix the code. I have two choices: travel 110 miles to Ed Wright in Tulsa and let him do a dyno tune or purchase an LS-1 Edit and tune myself. The cost will be about the same either way. Ed Wright would obviously do a better job not only in tuning out the 1870 code but squeeze a little more performance out of her. But what if something ever happened to Ed, God forbid. What if he decides to get out of the business, etc? I like to be a little more independent. What would you guys do?? BTW: this is a '97 so a Predator is out.
[Modified by MikeyD, 7:29 AM 9/15/2003]
Old Sep 15, 2003 | 08:41 AM
mfrnka's Avatar
mfrnka
Default Re: LS-1 Edit or Ed Wright?? (MikeyD)
I'd definitely go the LS1 Edit route. I'm no fan of the PCM locking business. I got caught in the TTS Powerloader locked programmer and poor service mess. Never again.
There is plenty of help and info available to help you with LS1 Edit.
Old Sep 15, 2003 | 08:49 AM
batsallover's Avatar
batsallover
I am on the same boat. I will be going with LS1 Edit for the versatility and when I get more serious mods, have a tuner use my copy of Edit for a dyno tune.
Old Sep 15, 2003 | 09:11 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
LS1 Edit - I'd stay away from Ed's locked PCMs too. My .02.
To LS-1 Edit or Ed Wright??
