I am torn between going with the Bosch 42lb injectors or the SVO 30lb -> 39lb@ LS1 FP. Whats the difference between these injectors other than 70 bones?
Phillip
Phil,
Go with the GM 42# injectors #24508208. They have the same pintle and coil as stock so you don't have to mess with the injector offset table in the PCM at all. They also have the same spray pattern as stock. These are the same onesthat I am getting.
Phil,
I'm running 36# SVO injectors in my NA, big cam, forged 347. These are the same as the Bosch 36# injector. They are about 42# at Corvette fuel pressure...
I am very happy with the performance of these injectors. Pulse width at WOT is about 13. This low PW/duty cycle results in zero KR because the PCM does not think the engine is at high load. I have a very good IFR table for these injectors that results in LTFT's of -1 across all the fuel cells. Let me know if you want this table and I will provide it to you...
Shirl
SDRE
