BE COOL RADIATOR / VARARAM...Does the job!
Old Sep 21, 2003 | 08:09 AM
vstella's Avatar
vstella
Default BE COOL RADIATOR / VARARAM...Does the job!
Well with the Hot and Humid weather down here in South Florida My temps were running 190's -215 degrees all the time. I just couldn't deal with it anymore :banghead: I picked up a new BE COOL radiator from Jegs. Com on sale and had Mike Norris Motorsports install it over the weekend. We dumped the Dextron , filled the new radiator with distilled water and the REDLINE Water Wetter...also went with the Hypertech 160 t-stat :yesnod: and......IT WORKED!! :hurray:
The car's coolant temps were down to 174-178 all day ..even with the A/C on in 94 degree weather at 85 mph on the drive home 220 miles!!..What a great product. Mike used the LS1 Edit to fine tune the car and turn the fans on just a little earlier. A/F is on the money and so far NO KR with the new NGK TR6 spark plugs ...a great package!:thumbs:
I can't tell you how happy I am with my choice. BE COOL makes a great product that does what it says it does. A solid 20 degrees cooler!!:smash: ..and not just the coolant temp. With the built in BE COOL oil cooler and my B&M Trans cooler both the oil and trans temps were down as well 15-20 degrees..I'm just a happy camper!! I love it when it all comes together.:D
We also installed the Vararam Intake with the HP filter and I will be giving that a good road test today..so far ..I like it over the VORTEX:yesnod: ..time will tell.
With a little cooler weather (70's) come November..I'll be back at the track hunting for those illusive 10's...but this cooling /intake should help. :thumbs:
[Modified by vstella, 8:10 AM 9/21/2003]
Old Sep 21, 2003 | 09:53 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (vstella)
Good stuff Vince,
how much did the BE COOL cost you? I may have to do that mod, my temps get pretty hot sometimes...
Old Sep 21, 2003 | 10:15 AM
90 droptop's Avatar
90 droptop
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (2000^C5)
Very COOL Vince.
VARARAM will help knock off a few tenths.
I never made it yesterday, as I was filling up the front skinnies with air, I noticed some brake fluid on the garage floor. Looks like I have a leaky line lock solenoid. Oh well, I'll be there next Saturday :sad:
Old Sep 21, 2003 | 10:26 AM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (90 droptop)
Vince,
how much was the radiator?
Old Sep 21, 2003 | 10:42 AM
vstella's Avatar
vstella
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (9D9LS1)
Vince,
.....9D9LS1
$581.00...on sale at JEGS.COM ..that's for an A4 with cooler. The M6 was even less.. :thumbs:
Old Sep 21, 2003 | 11:05 AM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
:cheers: Awesome Vince.....great combo :cheers: I have the exact saem set-up (except the intake which I want to change)!!!!!!!!
Old Sep 21, 2003 | 11:38 AM
WRK CAR's Avatar
WRK CAR
Hey Vstella,
I live in Texas and I just installed a Ron Davis radiator, and oil cooler and my 408 iron block engine temps are at 170 to 180 on a 90 degree day (before they were 200 to 225 ) oil temps are at 190 to 200 with the AC on. So I know how you feel. :thumbs:
[Modified by WRK CAR, 3:59 PM 9/21/2003]
Old Sep 21, 2003 | 12:14 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Sounds great.
Old Sep 21, 2003 | 12:29 PM
vstella's Avatar
vstella
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (WRK CAR)
Hey Vstella,
I live in Texas and I just installed a Ron Davis radiator, and oil cooler and my 408 iron block engine temps are at 170 to 170 on a 90 degree day (before they were 200 to 225 ) oil temps are at 190 to 200. So I know how you feel. :thumbs: ... WRK CAR
So I wonder .....What is the optimum operating temperature for maximum performance from the LS1-LS6. :rolleyes: ...I believe it's 178 degrees..Anyone know for sure?
Old Sep 21, 2003 | 12:31 PM
Operations's Avatar
Operations
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (rbartick)
I have a 6spd, could I use the trans cooler for a engine oil cooler?
Old Sep 21, 2003 | 01:09 PM
robsvette's Avatar
robsvette
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (Operations)
my best 11.5 run was on temps of 180 so that must be the best temp
that be cool rad will definitely be my next mod. either that or A&A's modified one. i got to see 230+ temps this summer with a 160 stat and programming for early fans with the AC on
Old Sep 21, 2003 | 04:44 PM
Mitch C's Avatar
Mitch C
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (robsvette)
We are running very similar setups, I also was running high temps. during the summer with A/C on. My car had sucked up a plastic shopping bag that partially blocked my radiator, since removing the plastic bag my temps don't go above 190 with the A/C on. Check the front of your radiator if you have not.
Old Sep 21, 2003 | 06:48 PM
robsvette's Avatar
robsvette
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (Mitch C)
THX mitch, i checked it out already and im clear of any debris. my car is already 4 years old and could have the same antifreeze or if not could have some cheap "no frills" brand antifreeze when i had all my work done. this is exactly why i like to do all my work myself when i can. i believe that this may be my heat problem. next year i will get a better radiator in the spring since i dont have this problem now and only on really hot 90 degree days
Old Sep 21, 2003 | 09:07 PM
vstella's Avatar
vstella
Very COOL Vince.
.......90 droptop
Oh my god!! :eek: I just tok the car on the expressway ...There is DEFINATELY an improvement in performance with the Vararam!! :smash:
I would tell you if it was not impressive....IT IS!! Thanks Patrick..great product!
Old Sep 21, 2003 | 09:43 PM
chuckster's Avatar
chuckster
Very COOL Vince.
.......90 droptop
Told ya bro ;)
Old Sep 21, 2003 | 10:59 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Vince,glad the set up works great for you.Same set up that I have.Try putting a B&M tranny cooler(26k-28k GVW) in front of it and you'll like it even better.My tranny temps are in the 165* range in traffic.:D
jerry :cheers:
Old Sep 22, 2003 | 12:41 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: BE COOL RADIATOR / VARARAM...Does the job! (XKR100)
Glad it works for you Vince. The Becool has worked very well for me also. If you don't track your car the BeCool is great. If you track I would go with a Ron Davis or buy an external oil cooler.
To BE COOL RADIATOR / VARARAM...Does the job!
Old Sep 22, 2003 | 12:53 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Congrats on the Becool! I've been running it for the last 2 years. I also just lowered the temps that the fans come on with LS1 edit . The high speed fans coming on eailier really do make a huge difference when it comes to low coolant temps! :cheers:
I also use distilled water with a dash of dextron and a 2 cans of 40 Below...
:cheers:
JB
Old Sep 22, 2003 | 07:57 AM
vstella's Avatar
vstella
Vince,glad the set up works great for you.Same set up that I have. Try putting a B&M tranny cooler(26k-28k GVW) in front of it and you'll like it even better. My tranny temps are in the 165* range in traffic.:D
jerry :cheers: .....XKR100
That's where the trans cooler is :yesnod: I'm OK with 174-178 ..even with the A/C on ...IN TRAFFIC !! :thumbs:
Old Sep 22, 2003 | 08:24 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Wise choice Vince! :cheers: Upgrading the cooling system as you increase HP is a MUST in my opinion.
I have the Ron Davis Radiator/Oil Cooler in my car and couldn't be happier with the temperatures my car runs at. Even back when I had heads/cam my temperatures would slowly creep up in traffic.. Now they never go over 185, even in traffic with very hot ambient temperatures. At lapping events on a roadcourse, there is a huge difference as well. My car is also always below 190 when Im in the staging lanes at the drags as well!
