EBCM question
Old Sep 21, 2003 | 11:53 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default EBCM question
I've been told my electronic brake control module needs replacing to fix my abs problem. Is that the electronic part of the brake device located in front of the motor with all the brake lines? If so, does the electronic controller part of that unit separate from the mechanical part or most the whole unit (electronic and mechanical) be replaced? Thanks!
Old Sep 24, 2003 | 12:11 AM
David-F's Avatar
David-F
Default Re: EBCM question (Rippied Z06)
Yes, the EBTCM(electronic brake traction control module) is two parts of which the electeronic part is servicable by it's self. What code are you getting?
David Fulcher
Old Sep 24, 2003 | 07:30 AM
Patches's Avatar
Patches
Default Re: EBCM question (David-F)
David! :seeya
Where ya' been? Emailed you a few times with no response. :(
Old Sep 24, 2003 | 12:23 PM
David-F's Avatar
David-F
Default Re: EBCM question (Patches)
Try again I've had computer problems from time to time, I've also be pretty busy.
David Fulcher
To EBCM question
