Has Your C5 Exhaust Ever Broken?
Old Sep 23, 2003 | 11:01 AM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
Default Has Your C5 Exhaust Ever Broken?
The Exhaust on my C5 LEFT side broke this morning. It sounds like a Log Truck. I think it broke over the axle..I took it to the Muffler shop and he goes on that it probably can't be fixed and needs to be replaced etc...Is he full of :bs Can it be fixed long enough for me to get B&B in a few weeks? What has been your experience?
Old Sep 23, 2003 | 11:03 AM
STL94LT1's Avatar
STL94LT1
Default Re: Has Your C5 Exhaust Ever Broken? (LowFlight)
Wrong forum LowFlight.
Old Sep 23, 2003 | 11:11 AM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Default Re: Has Your C5 Exhaust Ever Broken? (STL94LT1)
Really?:jester I have emailed a moderator...
Old Sep 23, 2003 | 12:04 PM
lotzahp's Avatar
lotzahp
it's VERY common for the flange welds to break, either on the muffler or the H-pipe side.
My H-pipe side broke, and when the dude was rewelding it I saw the other side was cracking. So he welded that too.
Old Sep 23, 2003 | 02:24 PM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Default Re: Has Your C5 Exhaust Ever Broken? (lotzahp)
Just got it fixed and that was exactly the case...Thanks
Old Sep 23, 2003 | 10:13 PM
TigerVette's Avatar
TigerVette
Do a search on this topic - we just discussed this the other day. The welds are programmed to break at 40K miles. lol
Find a low mileage set from an '02 or '03 in the parts section or on ebay for less than $100 and get a cheap upgrade.
Good luck,
Don
:steering:
[Modified by TigerVette, 9:14 PM 9/23/2003]
Old Sep 23, 2003 | 11:22 PM
No problems with mine, but I changed out the stock exhaust after only two months of ownership. I have read about a number of forum members having this problem.
Old Sep 24, 2003 | 10:22 AM
tabbruzz's Avatar
tabbruzz
Very common problem that can be simply welded....Hey is that vehicle on the left from "Damnation Alley"???? I love that movie....
Old Sep 24, 2003 | 11:17 AM
C5pilot's Avatar
C5pilot
Supposedly GM knows of the flange problem and some people can get them repaired or replaced under warranty.
Old Sep 24, 2003 | 11:52 AM
George8211's Avatar
George8211
I had mine replaced under warrenty. A weld broke lose on the driver side at about 28,000 miles. If your not under warrenty this might be a good time to consider an upgrade... performance exhaust. :thumbs:
Old Sep 24, 2003 | 01:15 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Has Your C5 Exhaust Ever Broken? (George8211)
My Corsas broke 3 times in the same spot. I finally just had them remove the mufflers and went w/ straight pipes. Kept the tips tho. Looked and sounded great. kaley
Old Sep 24, 2003 | 11:02 PM
OH Vette's Avatar
OH Vette
Mine broke about a week ago. I brought it into the local Chevy dealer yesterday to have them look at it figuring they would be the ones who can repair it. I had them change my oil while my '99 FRC (19K miles) was there. When they were done, the service guy tells me it can't be repaired, my exhaust flange broke off on the driver's side (muffler side of flange), and that I needed a whole new exhaust. They also said a nut had fallen off my my sway bar link and that I would have to buy a new link($100 installed) to get that nut since they didn't have that nut. They charged me $35.00 just to tell me the exhaust couldn't be fixed on top of the cost of the oil change and lube. It had to be up on the lift anways. Long story short, I went to a muffler guy and he welded the flange back on and welded the passenger side just in case. The muffler guy also found a nut for my sway bar link (no charge) and tightened it back up. That Chevy dealer must see $$$$ signs when somebody with a Vette comes in for a service. First experience with that dealer and probably my last. I am sure there are some good dealers around.
Al
[Modified by OH Vette, 4:19 AM 9/25/2003]
Old Sep 25, 2003 | 08:22 AM
LowFlight's Avatar
LowFlight
Senior Member
Cruise-In V Veteran
Thanks to all...I got it fixed... :thumbs:
Old Sep 25, 2003 | 09:41 AM
HOCKEY's Avatar
HOCKEY
I have had 3 different systems on with no problems but none have been on long enough to break.
Old Sep 25, 2003 | 10:12 AM
jdetar's Avatar
jdetar
Hey not to hi-jack this post but as someone mentioned I have a complete exhaust from manifold gaskets to the tips w/ 3K miles in perfect condition that I took off for my FLP+GHL :D . It's to much room for storage so if anyone wants it I can part with it pretty cheap.
To Has Your C5 Exhaust Ever Broken?
