seems like everybody has h/c packages, anybody out there have intake, exhaust, cam/springs with otherwise untouched heads? I cant afford the heads but may be able to go with cam/ springs, and a tune probably at Cartek if the gains would be worth it.
I'm planning on doing a cam, LTs, and a ls1 edit sometime next spring after my warranty is up (if I don't get an extended one). You can get the cam, install, and tune for around $1400 last I checked (lgm). Heads are another $3000 I think for like 20 rwhp or so.
From: Buy USA products! Check the label! Employ Americans
Re: anybody with cam only? (topless99)
It is a good bang for the buck mod. I would do cam, pulley, tune. First intake is not going to get you a bunch wait if you do heads IMHO. You will feel a good kick with a good cam. :thumbs:
So you made 100 RWHP with what is essentially cam and bolt on changes??
Yes that is correct. With tuning and all the essential bolt-ons my car just responded and those were the results. The fastest the car has gone was 11.75@126 at Hallsville on street tires, about two months ago in dead heat I drove the car to a 11.90@121 on street tires.
