Anyway to do a leak down test on engine stand?
Old Sep 23, 2003 | 09:55 PM
benelliwang's Avatar
benelliwang
Default Anyway to do a leak down test on engine stand?
I have an LS1 motor that I purchased 6 month ago. It has not been run for about 12 months. I finally got my butt going and put the new heads and misc parts in. I want to make sure the bottom end is good before I throw it into my car. But the cylinder walls has not seen oil for 12 months. Is there a way for me to oil up the piston rings/cylinder walls for a proper leak down test?
thanks
Old Sep 23, 2003 | 10:04 PM
leatherbeeC5's Avatar
leatherbeeC5
Navigator
Default Re: Anyway to do a leak down test on engine stand? (benelliwang)
Yes You just have to make sure the piston does not move from DTC. You do this in a car by putting in gear. However I use a breaker bar on the front of the motor and lock it against something. I like to use 100PSI for the test. This keeps it simple because you know your leaking if significantly drops below that point! :smash:
