Wiring for the challenge
Does anyone know or have the wiring diagram to this. Everything is color coded and has numbers on the connector. I don't know what color goes with what number. Anyone can help on this before I go and spend $100 for manuals.
Thanks guys.
http://www.asyst.net/images/pullcamout%20copy.jpg
[Modified by 2KVetteMan, 11:56 AM 9/24/2003]
[Modified by Patches, 3:23 PM 9/24/2003]
Jon
No link to my website is here.
He told me when you try to plug there is not much room to stretch it, he had to release the clip from the fan to get it over, but by then it was to late, the wires pulled out. A simple and honest mistake that can be made by anyone. :cheers:
I can hook you up but need a better description of the location and what it's attached to. When I do a search on "Active Handling" nothing comes up inside the manual. I can get you the connector views, color coding etc but need to know some more info.
later,
Wish I knew more about the part itself.
Thanks so much for the help, hope this will help.
Pin
Wire Color
Circuit No.
Function
A
BRN
641
Ignition Positive Voltage (ON)
B
BLK/WHT
1251
Ground
C
GRY
1787
Motor Feed (High) (MagnaSteer®)
D
RED
1242
Battery Positive Voltage (Solenoid Valve)
E
RED
1642
Battery Positive Voltage (Pump Motor)
F
WHT
345
Motor feed (Low) (MagnaSteer®)
1-3
Not Used
4
LT BLU
1764
Steering Wheel Position Sensor (SWPS) - B
5
Not Used
6
TAN/BLK
464
Delivered Torque
7
GRY
1524
Back Up Lamp Switch Input (JL4)
8
Not Used
9
LT BLU
20
Stoplamp Switch Input
10
LT BLU
1122
Class 2 Serial Data
11
GRY
1056
+5 Volt Reference
12
BLK
884
LR Wheel Speed Sensor (High)
13
WHT
883
RR Wheel Speed Sensor (High)
14
TAN
833
RF Wheel Speed Sensor (High)
15
YEL
873
LF Wheel Speed Sensor (High)
16
Not Used
17
LT BLU
914
SWPS Pulse
18
Not Used
19
WHT
1765
Brake Pressure Deferential Switch Input (Without JL4)
19
LT BLU
1659
Brake Pressure Deferential Switch Input (JL4)
20
LT GRN
1763
SWPS A
21
DK BLU
910
Yaw Rate Sensor Input (W/ JL4)
22
LT GRN/BLK
1338
Lateral Accelerometer Input (W/ JL4)
23
LT BLU
1059
SWPS Signal
24
BLK
901
Brake Pressure Sensor Input (W/ JL4)
25
ORN/BLK
463
Requested Torque
26
Not Used
27
ORN/BLK
556
Sensor Ground
28
RED
885
LR Wheel Speed Sensor (Low)
29
BRN
882
RR Wheel Speed Sensor (Low)
30
DK GRN
872
RF Wheel Speed Sensor (Low)
31
LT BLU
830
LF Wheel Speed Sensor (Low)
32
Not Used
[Modified by jmX, 4:57 PM 9/24/2003]
The bad news, no one in the this world has the connector that I need to rewire this thing back.
Been to
Fry's
Radio Shack
3 mom and pop auto parts store
Napa
AutoZone
Chevy dealer
Gm Dealer
Going to try another small independent auto parts store that I was told they will order the connector for me that connects to the wires. I need to load up my digital software so I can take a pic and you all can see what I am talking about. Keep everyone posted on my adventures. :party:
This is one of the pics that I have it shows the female connector. I lost one so I need to get one at least, I will buy by the dozen if someone can point out the part number. Been to two different Gm dealers and no dice.
http://www.asyst.net/images/pic1.jpg
http://www.asyst.net/images/pic2.jpg
http://www.asyst.net/images/pic3.jpg
Does anyone have or know how to get the description of the terminal connector that I need, my damn digital camera died and won't be able to post till tomorrow morning the actual pic.
Gene "Karshop" where are you brother!!! :smash:
Good Luck :cheers:
Shoot me an email at jmx@austin.rr.com and I'll do some research tonight. I can also probably get you a source for the terminals, although you're going to have to buy at least 100 of them. I also have the special crimper ($100) but you can use needle nose pliars and just hand crimp them yourself.
I'm at work right now so I dont have time to read up on which connectors are being used there. I may not be able to find out anything for that connector, but its worth a shot I guess.
Been up to 15 different stores now and they all refer to another and to another until I run into a wall.
I contacted Gene he might be able to help me, but have not heard from him after we exchanged e-mails. Contacted our other forum vendor Vette2Vette and waiting for an e-mail.
I tell you if you lose any of these terminals you are completely screwed. Worst case scenario I would have to buy the whole unit which I don't want to.
JMX I want to do the job right so if I have to use special crimplers I will pay the $100.00. I just need the connectors to get my baby back on the road. :cheers:
As for the crimpers, the pliars will be fine so don't worry about that. You have to manually crimp it, then solder the crimp to help bond the wire to the terminal and it'll be as solid as can be.
I spoken to Karshop and he has not gotten back to me.
