MT ET Streets
Old Sep 24, 2003 | 06:31 PM
gojo's Avatar
gojo
Default MT ET Streets
26x 11.50-17LT 9 11.5
These are the specs for the proposed ET Streets. The sidewall width is 11.5 and the rim called for is 9" width. Any problem with using 17x11 rims?
Old Sep 24, 2003 | 08:03 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: MT ET Streets (jfpilla)
I don't believe M/T will every come out with the 17" size. I talked to Jeggs this week, they have a delivery date of Nov. 7. It was suggested that M/T may be doing a market survey to see if there are enough customers to go into production.
In answer to your question, let me check my saved email.
Old Sep 24, 2003 | 08:06 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
A previous email I received from Mickey Thompson back in March.
Date: Mon, 24 Mar 2003 07:57:32 -0500
From: "Mark Waite" <mwaite@mickeythompsontires.com> Add To Address Book
Subject: Re: Rim Width
To: <wallstreetal@rcn.com>
17x10" is the strongly recommended size, though 17x9.5" up to 17x11" are
approved.
Mark Waite - Sales & Tech Support
Mickey Thompson Performance Tires & Wheels
330-928-9092 X156
330-928-0503 Fax
----- Original Message -----
To: <tech@mickeythompsontires.com>
Sent: Friday, March 21, 2003 10:27 PM
Subject: Rim Width
> What size wheel (width) would be recommended for use with the
> new 26x11.5x17 ET Streets.
> Thanks!
[Modified by wallstAL, 5:06 PM 9/24/2003]
Old Sep 24, 2003 | 11:26 PM
gojo's Avatar
gojo
Default Re: MT ET Streets (wallstAL)
Thanks for the info. They keep moving the date to the next month. I can wait until spring when the tracks reopen. :smash:
Old Sep 25, 2003 | 02:25 PM
MikeV's Avatar
MikeV
They are having a problem with seating the beads during mounting. I wouldn't look for these until Jan.
Mike V
Old Sep 25, 2003 | 03:01 PM
Face's Avatar
Face
Default Re: MT ET Streets (MikeV)
These were originally supposed to be released Sept. 2002. I wouldn't hold my breath. :rolleyes:
Old Sep 25, 2003 | 04:07 PM
Mitch C's Avatar
Mitch C
Default Re: MT ET Streets (Face)
:iagree:
If you are really interested in ET Streets, you might want to consider getting the 16 inch version. I think the 16 inchers will hook better than the 17s because of the wider sidewall of the tire.
To MT ET Streets
