Shift Knob Demon Key removal - this works!
Old Sep 24, 2003 | 06:59 PM
jschindler's Avatar
jschindler
Default Shift **** Demon Key removal - this works!
I posted the other day that there is a secret to removing the demon key. Someone IM'd me asking how to do it. It's hard to explain, so I took a picture to help. See picture below. Clamp on it with the vice grips. You MUST put a rag on the front of the **** to keep from tearing up the ****. Run the screwdriver though the vice grips as shown, and pry up on it using the flat blade of the screwdriver against the rag. This works for me every time with no trouble at all.
BTW, I read this a couple of years ago on the forum, but have no idea who posted it. Feel free to take credit if you posted this a couple of years ago.
Click on picture for larger image:
[Modified by jschindler, 5:59 PM 9/24/2003]
Old Sep 24, 2003 | 07:30 PM
MySea6's Avatar
MySea6
Default Re: Shift **** Demon Key removal - this works! (jschindler)
remember how we took out the **** in your 01 coupe?
Old Sep 24, 2003 | 07:32 PM
kenzietwo's Avatar
kenzietwo
Thanks for the very timely post. I have a new Hurst shifter coming in any day now so I'll definitely use your process. Looking at the picture is enough to see why it would make it easier.
Old Sep 24, 2003 | 08:19 PM
Midwayman's Avatar
Midwayman
Default Re: Shift **** Demon Key removal - this works! (kenzietwo)
heh, and I did it in 5 minutes with a flatblade screwdriver. :D Vice grips are probably a better choice though.
Old Sep 24, 2003 | 09:35 PM
samricky's Avatar
samricky
Default Re: Shift **** Demon Key removal - this works! (Midwayman)
I tried vice grips and every other tool in the garage and finally had to drill the entire shift **** off. :mad :mad :mad :banghead: :banghead: :mad :mad :mad
Old Sep 24, 2003 | 09:38 PM
Admiral Fairway's Avatar
Admiral Fairway
I used the vise grip, but instead of prying with a screwdriver, I tapped up on the vise grips with a hammer, this worked very well.
To Shift Knob Demon Key removal - this works!
