Fixed broken valve spring last night
Old Sep 27, 2003 | 10:26 AM
jmX's Avatar
jmX
Default Re: Fixed broken valve spring last night (SpinMonster)
The springs/retainers are all sold as a kit from LG so unless LG is selling people the wrong parts, the installed height should be correct.
Old Sep 27, 2003 | 12:38 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Fixed broken valve spring last night (jmX)
:iagree:
Old Sep 27, 2003 | 03:45 PM
Ben01C5's Avatar
Ben01C5
Default Re: Fixed broken valve spring last night (LG Motorsports)
:cheers: Lou :cheers:
It makes me feel really comfortable when you buy from a place like LGM, you have a problem and they are there behind you 110%.
Old Sep 27, 2003 | 03:47 PM
robsvette's Avatar
robsvette
Default Re: Fixed broken valve spring last night (Ben01C5)
:cheers: ben for getting that car back on the road!!! let us know if u run into that cobra & SS encounter again!
Old Sep 27, 2003 | 06:36 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
We now use a +.030 retainer, which, according to REV will give us plenty of margin before coil bind.
We only used what REV recommended and until this month, we have had almost no issues.
Lou G
Old Sep 28, 2003 | 10:12 AM
0Vette Stripes
Former Vendor
Lou G
Lou, what retainers have we used for the original G5X-2 cam when LG did a GP on that G5X-2 cam?
If we were using diff. retainers, should we replace them now or ""if it isn't broke, don't fix it"?
Old Sep 29, 2003 | 01:14 AM
SpinMonster's Avatar
SpinMonster
I don't use REV's at this time, I was defending them because I saw a statement made about their quality control. I think most vendors that know about these things would agree that it was a not so cool thing to say and anyone that does the math will agree that the application where they broke was an example of not so wise closeness in terms of coil bind.
I spoke to REV (Carlos) and he said the typical set-up for the 1116 rev springs (just chose this model as an example) with the retainers Thunder racing sells is dangerous for lift over.565-.570. Yes the springs will handle .600 with +.070 retainers or +.050 locks. There isn't a given correct setup. These things are varied from one application to another. Even if the valve is longer the heights are different. Are you using stock valves?
I don't trust anyone else's perfection. Lou is among the best of them. If you are saying that because something is sold as correct and vendors never make a mistake......
This was not a shot at LG, nor was it a shot at JMX. I am simply defending a product that is getting a bad rap: I am defending REV who isn't aware of this thread. As per REV get the coil bind of the spring, add the lift from Lou's cam, and if you are not at least .070 higher for your install heights THEY ARE WRONG.....FACT.
One other thing to keep in mind is that springs and retainers are not sold in 'sets' You pick a spring and it can be rated for up to .650 lift but the retainers sold with them from a vendor can't be correct for all set-ups. If you contact any one of the spring manufacturers, they have multiple retainers for every spring they sell. REV will ask you what the final height is you need to set at and then they sell you the correct retainer.
[Modified by SpinMonster, 6:27 AM 9/29/2003]
Old Sep 29, 2003 | 12:33 PM
Ben01C5's Avatar
Ben01C5
I took the valve cover and everything apart last night, just to go over everything and make sure all was well. I torqued the rocker bolts, but wanted to double check them, for some reason I was just paraniod the bolt might back out.
It probably took 15 minutes to take it all apart, look and put it back together.
I was already out in the garage doing the CLB bypass kit, so now my car is 100% again. :hurray:
Old Oct 2, 2003 | 11:21 AM
andreas g.'s Avatar
andreas g.
IF YOUR LOOKING FOR A GOOS LS1 SPRING CHECK OUTTHE RECENT POST
LS1 SPRING PROBLEM SOLVED. ITS ABOUT THE NEW COMP CAM DUAL SPRING, STOCK DIA. GREAT SPECS;
Old Oct 2, 2003 | 06:54 PM
FlamerF1's Avatar
FlamerF1
Default Re: Fixed broken valve spring last night (andreas g.)
Mine is also sitting with a broken spring, waiting for the Crane duel spring, stock dia. at least no apparent engine damage.
