Can someone explain these codes?
Old Sep 27, 2003 | 05:14 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Can someone explain these codes?
PCM code 135: Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
PCM code 155: Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
This is on my Procharger D1SC car. Not sure what they mean. Anyone?
Old Sep 27, 2003 | 06:31 PM
fredl11's Avatar
fredl11
Default Re: Can someone explain these codes? (diynoob)
Go here and look. They have an explanation
http://www.visi.com/~rhanson/obdII_codes-full-text.htm
Old Sep 27, 2003 | 06:47 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Can someone explain these codes? (fredl11)
Thanks Fred!
Old Sep 27, 2003 | 07:10 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
according to the manual :
if more than one HO2S DTC is set, this is a good indication that the HO2S fuse is open.
check all the related circuits going to all the heated oxygen sensors for a short to ground.
if all the wiring checks to be OK, it may be necessary to disconnect each HO2S one at a time to locate a shorted sensor.
Old Sep 27, 2003 | 08:17 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Can someone explain these codes? (ROCKnROLL)
More good info, thanks. Is this something that would be covered under factory warranty even though I have a supercharger?
Old Sep 27, 2003 | 10:35 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
good question !
i don't know.
alot of times it depends on the dealership you take it to.
keep your fingers crossed and if the first dealer turns you down try another one.
good luck.
To Can someone explain these codes?
