Hurst Install Question
Old Sep 27, 2003 | 10:52 PM
Shylor's Avatar
Shylor
Default Hurst Install Question
I'm trying to install my Hurst shifter on my 2003 Z06 tonight and I'm trying to reverse the rubber isolator boot but, there is a plastic ring on the inner opening making reversing it impossible. How do you do it? This ring seems to be glued on.
While trying to invert this boot that platic ring on it cut part of the boot....oh great! I need some help guys.
[Modified by Shylor, 8:13 PM 9/27/2003]
Old Sep 28, 2003 | 02:04 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Hurst Install Question (Shylor)
I don't remember anything being plastic. It may just be stiff to turn inside-out. Have a look at this link if you haven't figured it out by now. Should be easy. Look at step #17, I think this is what you are talking about. Let me know. :cool: :cheers:
http://www.c5forum.com/diy/hurstdiy.php
Old Sep 28, 2003 | 02:12 AM
Shylor's Avatar
Shylor
Default Re: Hurst Install Question (lager99)
No, it is a plastic rim on the rubber isolator inside lip. My isolator looks a little different. Maybe they changed the design slightly for 2003. I would post a picture but PhotoHost seems to be down again.
Old Sep 28, 2003 | 02:14 AM
lager99's Avatar
lager99
St. Jude Donor '06
In regards to the noise you mentioned on another thread, I noticed the most coming from the large whole remaining after you invert the boot. I drilled a hole in a tennis ball and slid it over the shifter. :yesnod: Works pretty good.
:lurk:
Old Sep 28, 2003 | 02:16 AM
lager99's Avatar
lager99
St. Jude Donor '06
Mines an '03 and I just don't recall this. Can you email me the picture? :skep:
Old Sep 28, 2003 | 02:26 AM
lager99's Avatar
lager99
St. Jude Donor '06
Or go here http://villagephotos.com/ it's a free host as well. :troll
Old Sep 28, 2003 | 02:56 AM
CAPN17's Avatar
CAPN17
No problem, no plastic on my 2003 Z06 rubber isolator boot, just a little stiff had to turn it inside out in slow stages.
Old Sep 28, 2003 | 02:59 AM
Shylor's Avatar
Shylor
Default Re: Hurst Install Question (CAPN17)
Well mine definately has a plastic ring. We are talking about Z06's right?
Old Sep 28, 2003 | 03:02 AM
lager99's Avatar
lager99
St. Jude Donor '06
:iagree: Same thing. '03 ZO6.
Old Sep 28, 2003 | 03:26 AM
Shylor's Avatar
Shylor
You can clearly see the plastic ring on the inner lip of the isolator. If I try to remove the ring it tears the rubber. Both sides of this part seem a tad different than other pictures I've seen of it. The car was shipped to the dealership in May and I took delivery in June of 2003.
[Modified by Shylor, 11:30 PM 9/28/2003]
Old Sep 28, 2003 | 05:05 PM
Shylor's Avatar
Shylor
What am I the only one with this style of isolator on a 2003 Z06?
[Modified by Shylor, 11:52 PM 9/28/2003]
Old Sep 28, 2003 | 06:12 PM
Shylor's Avatar
Shylor
Well I decided I had no choice but to cut the ring off the boot. It was molded onto it and would not invert. From looking at it the plastic ring seemed to click into the stock shifter's little boot, at the base. Making for a tighter connection. Maybe that is why they did a design change.
If want to return to my stock shifter the isolater boot will not be as tight as it was but should still work.
Anyone know of the part number for the isolater boot?
[Modified by Shylor, 11:34 PM 9/28/2003]
Old Sep 28, 2003 | 08:03 PM
lager99's Avatar
lager99
St. Jude Donor '06
I got your pic, sounds like you're done anyways. I sure don't recall that. :confused:
:cheers:
Hope you have it installed now. How do you like it? :steering:
Old Sep 28, 2003 | 09:40 PM
Shylor's Avatar
Shylor
Oh man what a difference! I didn't change the shifter springs and it's great. I also did the PVC cap mod and it fits very nicely. The stock shift boot is a bit baggy but not as bad as I thought it would be.
[Modified by Shylor, 11:36 PM 9/28/2003]
Old Sep 29, 2003 | 12:56 AM
lager99's Avatar
lager99
St. Jude Donor '06
:cheers:
Old Sep 29, 2003 | 07:38 PM
Admiral Fairway's Avatar
Admiral Fairway
Now for a real difference try changing the trans fluid to a synthetic.
Old Sep 29, 2003 | 08:26 PM
lager99's Avatar
lager99
St. Jude Donor '06
Default Re: Hurst Install Question (Admiral Fairway)
Does that make a big difference? :confused: :cool:
To Hurst Install Question
Old Sep 29, 2003 | 08:32 PM
FlyinNOE's Avatar
FlyinNOE
What brand and how much fluid?
Thanks.
Brian :flag
Old Sep 29, 2003 | 08:41 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Default Re: Hurst Install Question (FlyinNOE)
I used Mobil 1 in the 98. You will get many answers as to which is best.
Old Sep 29, 2003 | 09:07 PM
NVR BRNG's Avatar
NVR BRNG
[QUOTE]Oh man what a difference! I didn't change the shifter springs and it's great. I also did the PVC cap mod and it fits very nicely. The stock shift boot is a bit baggy but not as bad as I thought it would be.
To shorten your stock boot: Take the boot off the car and push the tip of the boot inward to shorten the boot approximately 1".
IMHO, this works very good and there's no additional cost involved. You can also easily reverse the process if you want to go back to your stock shifter, or whatever.
When you replace the boot and install your shifter ****, the boot will be less baggy and virtually no one but you will know any different.
Or you could spend alot of extra money for a "custom" shorter boot.
