Very bad Tansmission problem =~(
Old Sep 29, 2003 | 03:46 AM
Cartier1's Avatar
Cartier1
Default Very bad Tansmission problem =~(
I ran my car today and launched pretty well on 1st,it did the 2nd shift and then the car goes like neutral =(,it cannot do the upshift to 3rd :cry and the speeodmeter goes crazy!:crazy:
only at WOT.
it is an A4 98!
anyone with the same problem :confused:
[Modified by Cartier1, 3:30 PM 9/29/2003]
Old Sep 29, 2003 | 03:51 AM
torched you's Avatar
torched you
Default Re: Very bad Tansmission problem =~( (Cartier1)
does r work.?
Old Sep 29, 2003 | 04:09 AM
Cartier1's Avatar
Cartier1
Default Re: Very bad Tansmission problem =~( (torched you)
yeap it works but cannot go go to the 3r shift,goes like neutral i think :rolleyes:
Old Sep 29, 2003 | 04:15 AM
torched you
does d work or when it gets out of 2 there nothing?
Old Sep 29, 2003 | 04:25 AM
Cartier1's Avatar
Cartier1
D works,and the same problem is when i launch on 1st and i upshift to 2!
the problem is on bouth!
i mean the problem is from 2nd to 3rd in D or OD or manual!
[Modified by Cartier1, 9:30 AM 9/29/2003]
Old Sep 29, 2003 | 04:46 AM
torched you
sounds simple as blowed out 3 gear :( sorry to say but i could be wrong
Old Sep 29, 2003 | 04:50 AM
Cartier1's Avatar
Cartier1
thanks a lot for your help!!
tomorrow i will go to check that trans and repair it if its necessary :cry
:seeya
Old Sep 29, 2003 | 04:58 AM
torched you
good luck :cheers: :seeya
Old Sep 29, 2003 | 12:50 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Call Chuck at FLP and tell him whats happening and see what he thinks.
:thumbs: The no. 630-820-9294 :cheers: .
Old Sep 29, 2003 | 02:05 PM
kromberg's Avatar
kromberg
Default Re: Very bad Tansmission problem =~( (LittleBoyBlu99)
Third to fourth clutch packs are fried. When I nuked mine, those where the exact symptoms. Runs about $150ish to replace them. Shipping cost me about $250 :cry
Keith
Old Sep 29, 2003 | 02:30 PM
SFVetteman's Avatar
SFVetteman
Default Re: Very bad Tansmission problem =~( (kromberg)
Keith
You should try to work a deal on a quanity of them and some of the other clutch packs as well. With your power and a stock A4, it's worth stockpiling them :nopity
Old Sep 30, 2003 | 01:37 AM
Cartier1's Avatar
Cartier1
Default Re: Very bad Tansmission problem =~( (SFVetteman)
Problem Solved!!!! :D
were those speedo wires,a wire was burned on the exhaust,i changed those cables for the new ones and the speedometer is working well and the shifts too!!!! :D :D :D :auto: :hurray: :steering:
that makes me feel so happy right now!! :crazy: :D :)
To Very bad Tansmission problem =~(
