voltmeter says...
Old Sep 29, 2003 | 11:54 PM
JJF's Avatar
JJF
Default voltmeter says...
DIC said charging system problem, then did not come back on screen after a quick ride. Voltmeter at 13.6 Is that OK?
[Modified by JJF, 4:55 AM 9/30/2003]
Old Sep 30, 2003 | 12:36 AM
mapman's Avatar
mapman
Default Re: voltmeter says... (JJF)
Any DTC fault codes?
Old Sep 30, 2003 | 08:46 AM
te51cle's Avatar
te51cle
Mine did that just once and didn't reoccur so I took a deep breath, assumed it was a glitch and went on driving it as normal. No further problems. I'd only worry if it happened 2-3 times in succession.
The DIC voltmeter said 11.8 when the ignition was on but engine not running, I checked the (AGM) battery with a standalone voltmeter and it was a more normal 12.5 or so.
Old Sep 30, 2003 | 09:55 AM
JJF's Avatar
JJF
Default Re: voltmeter says... (te51cle)
Thanks...I feel better!!
Old Sep 30, 2003 | 11:03 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
13.6 is lots. :chevy
To voltmeter says...
