Does Royal Purple Rr. Gear Fluid Require the Additive?
Old Sep 30, 2003 | 09:19 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Does Royal Purple Rr. Gear Fluid Require the Additive?
:confused: does it require the limited slip additive?
Old Sep 30, 2003 | 09:21 PM
davidfarmer's Avatar
davidfarmer
Default Re: Does Royal Purple Rr. Gear Fluid Require the Additive? (Buckmaster)
I would add it to ANY fluid, even the overpriced Royal Purple.
Old Sep 30, 2003 | 09:25 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Default Re: Does Royal Purple Rr. Gear Fluid Require the Additive? (davidfarmer)
:D OK cool. Thank you. So obviously in your opinion the stock fluid is just fine......and RP or Redline or Amsoil provides no additional benefits? Looking for opinions. Thanks :seeya
Old Sep 30, 2003 | 10:20 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
We just changed over to Rp gear lube(75-140wt.) was told I did not need the additive.
jerry
Old Sep 30, 2003 | 10:27 PM
1SlowC5's Avatar
1SlowC5
It does not require the additive but I put in in anyway when I put in my 3.90's.
By the way Royal Purple is very good stuff.
Old Oct 1, 2003 | 03:26 AM
NastyC5's Avatar
NastyC5
You don't need the additive with RP. I used it in my C5 and I'm about to put it in my Viper :yesnod:
Overpriced :confused: It's less expensive then the GM crap and around the same price as Moble 1 after you purchase the additive.
Old Oct 1, 2003 | 08:21 AM
XKR100's Avatar
XKR100
Default Re: Does Royal Purple Rr. Gear Fluid Require the Additive? (NastyC5)
:iagree:
To Does Royal Purple Rr. Gear Fluid Require the Additive?
