lowing a frc
Old Oct 2, 2003 | 09:08 PM
torched you's Avatar
torched you
Default lowering a frc
on the rear rubber bushings with the 2 lines in them if i cut both lines and just had 1 piece how much drop would that get me in the rear..? any ideas
[Modified by torched you, 9:09 PM 10/2/2003]
[Modified by torched you, 9:10 PM 10/2/2003]
Old Oct 2, 2003 | 09:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: lowing a frc (torched you)
Just get some longer (1/2" x 6.5" long) grade 5 bolts and some locknuts and keep your bushings intact. The longer bolts will allow you to slam it as much as you want.
:cheers:
Old Oct 2, 2003 | 09:13 PM
boblackhardtop's Avatar
boblackhardtop
Default Re: lowing a frc (Y2Kvert4me)
I got A and A rear lowering kit, like new $25 shipped.
Got DRM coilover :cool:
Old Oct 2, 2003 | 09:14 PM
torched you
good idea for every inch i take out at the leaf spring will i get a inch of body drop or more..? :cheers:
Old Oct 2, 2003 | 09:32 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Actually, the adjustment is more sensitive than that. You are dealing with angles and a lever effect.
I seem to recall reading a forumula for it, but it's more like a 2:1 ratio (ie 1/2" bolt adjustment= 1" drop).
The stock bolt is 6" long, but only 5 3/8" is threaded. A 6.5" bolt will get you at least 2" drop if the nut is loosened all the way. I think on my car I have about 6 threads exposed above the nut, so I still could drop mine more if I wanted. People have used 7" long bolts too, but a 6.5" should suffice.
:cheers:
[Modified by Y2Kvert4me, 8:36 PM 10/2/2003]
Old Oct 2, 2003 | 10:33 PM
torched you
thanks for your help keep the stock bolts in the front :confused: :cheers: :cheers:
Old Oct 2, 2003 | 11:56 PM
YOULLUZ's Avatar
YOULLUZ
In my sig you'll see mine lowered on stock bolts and trimmed bushing.. let me know if you have any questions.
Old Oct 3, 2003 | 02:05 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
I pulled the bolts out in the front and got longer bolts for the rear. I used 1/2 x 6.5 grade 8 bolts and left 12 threads showing. It is even w/ the front.
Old Oct 3, 2003 | 10:15 AM
TIKTGTR's Avatar
TIKTGTR
Default Re: lowering a frc (torched you)
I removed my front bolts and shaved 1/3(one ring) off the rear bushing for the ride height I was looking for.Found it :D car looks and handles great :cheers:
Old Oct 3, 2003 | 12:29 PM
torched you
Default Re: lowering a frc (TIKTGTR)
thanks for the help guy's just one thing when you say removed front bolts ? did yous put anything back in there or they just out and thats it :eek: :cheers: :cheers: :auto:
To lowing a frc
