Z06 High Flow Manifold
Old Oct 3, 2003 | 11:01 AM
gcvette's Avatar
gcvette
Default Z06 High Flow Manifold
Will I notice the difference in power if I install a Z06 High Flow Manifold? I have already installed a Vararam System (with an upgraded duct), Corsa Exhaust, Mass Air Flow Sensor, X pipe, and 3.90 gears. I personally felt an immediate difference when I installed the vararam, exhaust and gears, but I was wondering will I feel a difference with the Z06 manifold. I plan on installing TPIS Long Tube headers next, but I was told that I should first install the Manifold. Any thoughts/opinions? Thanks :confused:
Old Oct 3, 2003 | 11:06 AM
jmX's Avatar
jmX
Default Re: Z06 High Flow Manifold (gcvette)
Will you FEEL a difference? No.
Will you gain some power? Probably.
In my personal opinion, if you have heads/cam/headers, the 2001+ intake manifold (its not a Z06 manifold, its a manifold used on ALL 2001 and later LS1's and LS6's) would be worth the price. If you dont plan on doing cam/heads/headers, the money may be better spent elsewhere for now.
Old Oct 3, 2003 | 11:15 AM
gcvette's Avatar
gcvette
Default Re: Z06 High Flow Manifold (jmX)
Thanks!! When you say that the money could be spent elsewhere, where exactly would you recommend :confused:
To Z06 High Flow Manifold
