Recommendations for a cam
Old Oct 3, 2003 | 04:24 PM
badboy27's Avatar
badboy27
2nd Gear
Default Recommendations for a cam..
I don't want anything I can't drive with for a daily driver or for long trips. I am having my motor reringed and would like to have the cam swapped since they will be rebuilding it anyway. Any recommendations?
thanks! :seeya :flag
[Modified by badboy27, 9:25 PM 10/3/2003]
[Modified by badboy27, 9:27 PM 10/3/2003]
Old Oct 3, 2003 | 04:39 PM
blktie8's Avatar
blktie8
Default Re: Recommendations for a cam.. (badboy27)
Check with Thunder racing for the best cam to install?
Should be 114 LSA
I am installing 224 561 114
John
Old Oct 3, 2003 | 05:01 PM
robl45's Avatar
robl45
what is this with people worrying about being able to drive the car daily?? I"m just worried about the fuel mileage. As long as it idles, I say get the baddest cam you can. Otherwise, you'll be wishing you did later.
Old Oct 3, 2003 | 05:12 PM
Karl_in_Chicago's Avatar
Karl_in_Chicago
Default Re: Recommendations for a cam.. (robl45)
What is this with people worrying about fuel mileage?? I'm just worried about going fast. Who buys a sportscar and worries about mileage? :D
Just funnin' with you, robl45. :)
For the record, I do like it when I can tell people that I can do 85 mph from Chicago to Atlanta and get 31 mpg; but I wouldn't care if it was 21 mpg as long as it still drove like it does! :cool:
Old Oct 3, 2003 | 05:53 PM
robl45's Avatar
robl45
Default Re: Recommendations for a cam.. (Karl_in_Chicago)
31 MPG? Do you get that in the USA or in Fantasy land? Seriously, I'm not trying to be a jerk, but how do you guys come up with these figures? I'm lucky if I can get 25MPG on the highway and 18 driving around town. I know the AC is always on, but I have a stick and I'm in sixth as quick as possible. But with regards to the cam issue, if its a stick, it should be drivable no matter what. all of the cams I've seen here seem to have plenty of low end torque. I had a pretty aggressive cam in my TA and I drove it every day without any problems
Rob
Old Oct 3, 2003 | 06:02 PM
Karl_in_Chicago
Well . . . I note my starting mileage, I print the receipt from the gas pump each time I fill up, and then I divide miles driven by gallons pumped. It's usually pretty close to the DIC numbers but I depend more on good old fashioned math to make sure there's no computer funny business going on. Understand that this is all with a bone-stock '99 coupe being driven at mostly steady-state speeds over long distances in 6th gear. I put on a Blackwing last night and am putting on a Z06 Ti exhaust tomorrow but I can't see either of those changes making material changes to my mileage - but like I said, I couldn't care less if they do.
Old Oct 3, 2003 | 07:27 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
Default Re: Recommendations for a cam.. (blktie8)
Should be 114 LSA
John
:iagree: The 224/.561/114 would be a very good cam to fit your requirements...IMO. :thumbs:
In fact, 21MC right here in Dallas can fix you right up with a cam like that. They do nice work, and what a super clean shop!!!:cheers:
[Modified by NIGHTMARE...2001, 6:32 PM 10/3/2003]
Old Oct 3, 2003 | 11:17 PM
C7GrandSport's Avatar
C7GrandSport
Should be 114 LSA
John
After much research, my car's at the Vette Doctors right now having this cam installed. It was the most aggressive cam I could go with that will still pass NY emissions. Paul @ Thunder Racing was very helpful in the selection process.
Old Oct 4, 2003 | 12:05 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Recommendations for a cam.. (c5grandsport)
I have an MTI T1, 221,.558,112lsa. I drive this car everywhere. I experienced no loss in highway gas mileage with this cam. Consistantly 30mpg with the AC on in 6th gear. I have put 16,000 miles on my car since the cam swap.
Being 112lsa it did require some tuning for idle, which I have done myself using LS1Edit.
Eric
To Recommendations for a cam
