PIAA 1100 install
Old Oct 6, 2003 | 10:56 AM
splinters's Avatar
splinters
Default PIAA 1100 install
Anyone know where to get instructions for replacing the factory fog lights with the PIAA 1100s? :confused:
Old Oct 6, 2003 | 11:06 AM
woosch's Avatar
woosch
Default Re: PIAA 1100 install (splinters)
Go to tech tips and use the install procedure for the Z06. You won't need to make new brackets or buy a dash switch are about the only differences in putting them in a car that had factory fogs.
Old Oct 7, 2003 | 08:23 AM
splinters's Avatar
splinters
The directions in "tech tips" aren't perfectly clear. The harness I have from PIAA has three wires going into the switch (black, red, and white). There is a white with red dots wire coming off the connector to the switch, that is for switch power. :confused:
Old Oct 7, 2003 | 09:15 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
My PIAA harness has a [black and two white w/red dots] to the switch.
You don't need the black or one of the white w/red, the other white w/red is
spliced into the purple wire under fuse 39. My guess would be to splice the red wire, cut the other two.
Hope it work for you! :thumbs:
To PIAA 1100 install
