Can someone explain code P0441 ?
Old Oct 6, 2003 | 12:07 PM
WAEC5's Avatar
WAEC5
Default Can someone explain code P0441 ?
My check engine light came on this weekend traveling(200 miles from home).
The only place open was an AutoZone and I had them read the code with their scan tool (P0441). The clerk said that the problem was fuel related.
Can someone expain this code in detail? BTW the engine seems to be running fine :chevy
Thanks in advance,
Bill
Old Oct 6, 2003 | 12:09 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Can someone explain code P0441 ? (WAEC5)
P0441 EVAP System No Flow During Purge
Old Oct 6, 2003 | 05:32 PM
WAEC5's Avatar
WAEC5
Default Re: Can someone explain code P0441 ? (ICULUKN-C5)
Details please :confused:
Old Oct 6, 2003 | 07:24 PM
Cirrus8's Avatar
Cirrus8
Is your gas cap on tight. If it leaks air, the evap system will go into a tissy. :D :D
Old Oct 6, 2003 | 08:06 PM
SFVetteman's Avatar
SFVetteman
You must have a ’97 or ‘98 as the ’99 and up split EVAP system code P0441 into five different codes. As mentioned a loose or faulty gas cap can trip the code. Also, Mini-Fuse 19 (10amp), which is located in the fuse box next to the battery, could be bad.
If the gas cap and the fuse are both ok then things get a bit complicated as the problem could be in the EVAP vent or purge solenoid valve circuits, EVAP canister vent blocked, kinked or damaged EVAP system lines, or possibly a bad fuel pressure sensor.
Old Oct 6, 2003 | 09:51 PM
OldSStroker's Avatar
OldSStroker
BTW, You can read any codes on the DIC without Autozone's help.
If you don't have a shop manual, you can find all the codes on the web, or here.
http://www.frankhunt.com/FRANK/hobbi...DTC_Reset.html
Old Oct 6, 2003 | 10:21 PM
WAEC5's Avatar
WAEC5
Default Re: Can someone explain code P0441 ? (OldSStroker)
Thanks,
Fuse looks OK. Gas cap gasket is cracked. I'm ordering shop manual tomorrow ;)
To Can someone explain code P0441 ?
