seat rocking???
Old Oct 6, 2003 | 02:43 PM
corvettetx's Avatar
corvettetx
Default seat rocking???
My seats rock forward when braking? Is this typical, and is it something that can be adjusted. Or am I SOL?
Thanks! :cool:
Old Oct 6, 2003 | 02:46 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Re: seat rocking??? (corvettetx)
My seat rocks in place, it doesn't actually slide forward, if that's what you mean... It's a common problem.
Old Oct 6, 2003 | 02:54 PM
corvettetx's Avatar
corvettetx
Default Re: seat rocking??? (mebrahimi)
Yes, that is what I mean. Is there any way to fix it? Thanks for the input!
Old Oct 6, 2003 | 02:55 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
http://corvetteactioncenter.com/kb/q....php?qstId=277
Old Oct 6, 2003 | 03:57 PM
C5Nate's Avatar
C5Nate
Kansas City Area Coordinator
St. Jude Donor '08-'09-'10-'11,'13
Default Re: seat rocking??? (1999 White C5 Coupe)
$437.40 for the replacement from http://www.gmpartsdirect.com
Old Oct 6, 2003 | 04:21 PM
tlaselva's Avatar
tlaselva
I would first ensure your seat's bolted down tightly.
You have 4 bolts holding the seat frame to the floorboard, and another 4 bolts holding the seat to the frame.
You'll likely have to take the seat out to access the bolts holding the seat to the frame. They're on the under side of the seat.
[Modified by tlaselva, 4:23 PM 10/6/2003]
Old Oct 6, 2003 | 04:52 PM
loudes13's Avatar
loudes13
Default Re: seat rocking??? (tlaselva)
same prob. why anyone would spend another $400 for another defective seat?
Old Oct 13, 2003 | 04:48 AM
OJ250's Avatar
OJ250
Cruising
mine was covered under waranty
Old Oct 14, 2003 | 01:04 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: seat rocking??? (OJ250)
I had another seat problem that was covered under warranty and when I got the car back, the seat would rock intermittenly. Then all of a sudden, about three months ago, it stopped rocking. I'm not sure what happened but I'm sure glad that it went away. :yesnod:
Old Oct 14, 2003 | 10:01 AM
Purerock105's Avatar
Purerock105
Default Re: seat rocking??? (FunDriver)
There's NO quick/temp fix for say $20 rather than $400+...?
Yikes... :eek: Mine only does it depending on the exact adjustment
that seat currently has.
:crazy: :rolleyes:
Old Oct 14, 2003 | 02:15 PM
corvettetx's Avatar
corvettetx
Default Re: seat rocking??? (Purerock105)
I checked and the seat is bolted down as tight as it can be. The local dealership wants an arm and a leg. I guess I will have to deal with it :mad ! Thanks for the input!
Old Oct 14, 2003 | 02:31 PM
DSTJ99's Avatar
DSTJ99
:crazy: :rolleyes:
The first person to come up with one will be a very wealthy man:D
until then, we are stuck with the rocking or the large bill.... :cry
Old Oct 14, 2003 | 06:10 PM
Belloc's Avatar
Belloc
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: seat rocking??? (DSTJ99)
I use the 4x4 trick. Just cut a 4x4 about 12 inches long wrap in a black piece of material and run you seat back against it. It's worked great for me.
To seat rocking???
