Should I install a TC now ???
Old Oct 6, 2003 | 05:55 PM
mstewart's Avatar
mstewart
Default Should I install a TC now ???
I'm installing on my 98 a4 ( Corsa exhaust, Blackwing intake, 3.42 rear end,LS-1 edit tune ) should I go for a TC ( $ running low ) car is for every day use / no racing - just enjoy the feeling. :lol:
Old Oct 6, 2003 | 06:12 PM
RWhite's Avatar
RWhite
Default Re: Should I install a TC now ??? (mstewart)
Yes, If I were you I would find a used one and then have it installed when they do the gears. A good shop will not charge more than a few extra dollars to install since its already apart and ready to be stabbed.
Used TC's range from $400 and up, but are worth every $$$$$$$.
Check the used part forum.
Old Oct 6, 2003 | 07:03 PM
mstewart's Avatar
mstewart
What type of TC would you use for a daily driver ( no racing )
Old Oct 6, 2003 | 07:32 PM
RWhite's Avatar
RWhite
Yank seems to have alot of TC's to choose from.
Go here and look for the one that suites your desire -->http://www.converter.cc/general_motors.htm#GM%20C-5
I just installed a PT4000.
Maybe someone else can comment that has a setup like yours.
[Modified by RWhite, 6:33 PM 10/6/2003]
Old Oct 6, 2003 | 07:35 PM
Killrwheels's Avatar
Killrwheels
Default Re: Should I install a TC now ??? (RWhite)
I have the same setup and Mike at Yank suggested SY-3500 . Daily driver for street..... with 3.42's and air intake upgrades.
Selling new, never used for 750.00 shipped/picked up. Sy-3500 bought directly from Yank a month prior.
[Modified by Killrwheels, 10:18 AM 10/7/2003]
Old Oct 6, 2003 | 08:44 PM
SFVetteman's Avatar
SFVetteman
I would keep in mind that although many have gone to an aftermarket TC with a stock tranny with no ill effects, the stock A4 has pretty much all it can handle with the torque multiplacation from the stock converter. You might be one of those that can do it without problems and then again maybe not :cheers:
Old Oct 6, 2003 | 09:20 PM
402Sam's Avatar
402Sam
Default Re: Should I install a TC now ??? (SFVetteman)
I would also look into getting a tranny cooler if you plan on goin with a convertor higher then 3000 stall. I higher stall will heat that tranny up quick and then its all down hill from there for the tranny.
Old Oct 6, 2003 | 09:58 PM
C7GrandSport's Avatar
C7GrandSport
From a labor standpoint, it makes no sense to do the gears without doing the TC at the same time. If you don't, you'll just end up going back and paying double labor once you realize you need the TC. The TC is going to give you the biggest seat of the pants improvement of all the things you mentioned. Pro Torque 2900 stall costs around $600. Higher stall Yank for drag racing, which it doesn't sound like you're doing.
Old Oct 7, 2003 | 06:01 AM
Mitch C's Avatar
Mitch C
Default Re: Should I install a TC now ??? (c5grandsport)
:iagree:
Without question install your gears and T/C at the same time and save on not having to pay labor twice. A good mild street converter would be the Yank 3000 or the Vig 2800. The Vig is less expensive than the Yank, the Vig costs about 699.00 the Yank is about 100.00 more.
[Modified by Mitch C, 5:03 AM 10/7/2003]
Old Oct 7, 2003 | 08:08 AM
vstella's Avatar
vstella
YES !! ......Go with a ProTorque 2800 or Vigilante 2800....either will serve you well on the street with little or no PCM modifications.... :yesnod: I would consult with our resident CF transmission expert Steve Atkins of www.eastcoasttransmissions.com :thumbs: He KNOWS his stuff and is very reasonable for install pricing. His shop is in Fort Lauderdale on Dixie Highway!! Mention my name he'll treat you right :thumbs:
Don't forget the TRANSGO shift kit :yesnod: It's a must have when changing gears and converters :thumbs: :thumbs:
Old Oct 7, 2003 | 08:17 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Should I install a TC now ??? (vstella)
If you are going to be installing 3.42s, and can spare the cash for a torque converter, this is definitely the time to do it. For a daily driver, with 3.42s, I HIGHLY recommend the SUPER YANK 3500 (aka SY3500). It's low torque multiplication ratio keeps your car from being a total animal off the line, which works out good since you will be running with street tires. Don't let the 3500 stall speed number scare you. This converter is awesome on the street.
Feel free to email me if you have any questions or would like some pricing on YANK converters.
Old Oct 7, 2003 | 07:01 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Should I install a TC now ??? (MattG)
:iagree:
However know that this set up will also allow you to get out of your runcraps and into some better tires quickly cause you will wear them out practicing your launch technique :lol:
Old Oct 8, 2003 | 08:13 AM
blktie8's Avatar
blktie8
SY3500 342 and don't forget the TRANS - GO
Had it in about a year and have only one thing to say (Pleased)
John
[Modified by blktie8, 8:15 AM 10/8/2003]
Old Oct 8, 2003 | 07:42 PM
1g1yy's Avatar
1g1yy
Default Re: Should I install a TC now ??? (blktie8)
Exactly what does the Transgo kit do that cannot be done with a programmer such as a Hypertech? Thanks. :confused:
Old Oct 8, 2003 | 07:53 PM
jimbalaya's Avatar
jimbalaya
Default Re: Should I install a TC now ??? (1g1yy)
:lurk:
Old Oct 8, 2003 | 09:11 PM
dads01dream's Avatar
dads01dream
Are then any concerns with buying a "used" T/C??? How do you know you're getting a good one and not something on the verge of failing?
:cheers:
To Should I install a TC now ???
