help me with this problem
Old Oct 6, 2003 | 09:27 PM
Act.RT's Avatar
Act.RT
Default help me with this problem
when driving on the highway the car acts acts like its going to flood out until i floor it, and when i exit it does it again until i give it gas to clear it up. whats up are my injectors going bad or should i change my plugs. or maybe the fuel pump is going bad please give me some input. :banghead:
Old Oct 6, 2003 | 09:44 PM
OldSStroker's Avatar
OldSStroker
Default Re: help me with this problem (Act.RT)
Have you removed/changed any of the inlet air ducting between the MAF and the engine recently? Any air leaks here can drive the comuter crazy. Easy to check.
Always check the easy (cheap) stuff first.
My $.02
Old Oct 6, 2003 | 09:48 PM
Act.RT's Avatar
Act.RT
Default Re: help me with this problem (OldSStroker)
yes i checked the car for leaks there are none, i even though it was the adjustable fuel pressure reg. but i had it checked it was fine, still very confused. :banghead:
Old Oct 6, 2003 | 11:39 PM
C5XTASY's Avatar
C5XTASY
You may want to clean your MAF (very, very gently) or the MAF itself may be bad. Your dealer can tell you if any codes have been set. Good luck!
Ed
To help me with this problem
