BFG DR Problem Please help
Old Oct 8, 2003 | 12:55 AM
Cobra Skinner's Avatar
Cobra Skinner
Default BFG DR Problem Please help
Hey guys I just put 295/35/18 on the back wheels of my z06.. I took my car for a test drive and the back end seems to float... It scary its almost wobbly... The tires have 35 psi... What the heck is going on... ?? Please help me
Old Oct 8, 2003 | 01:07 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Re: BFG DR Problem Please help (Cobra Skinner)
Way, way too much air dude!!!!!!!!!! Lower to 20 psi for the track, you can play with that # to find the best sticking point. That will eliminate the float, air them back up for the drive home. :D
Old Oct 8, 2003 | 01:23 AM
Cobra Skinner
Default Re: BFG DR Problem Please help (ScreaminDemon)
When I take this on the highway is when I get float though and thats at 35 psi... not at the track... Could i run them at 20 psi all the time so I won't get float?
Old Oct 8, 2003 | 01:28 AM
Red C5's Avatar
Red C5
If you are comparing the ride to the runflats, it does feel very different at first. :)
I would drop the pressure down to abou 28psi. On drag radials I usually will run 25psi at the most. If you think your tires are wobbly, you should take a ride on ET streets at 15psi on the freeway. :lol:
Play with the pressure a little. Don't worry, the car will handle just fine. :cheers:
Old Oct 8, 2003 | 02:20 AM
ScreaminDemon
Guess I have a one track mind. Just lower the pressure til they break-in.
Old Oct 8, 2003 | 08:12 AM
Cobra Skinner
Ok also will then run at 25 or 28 psi for long period of time on the highway such as 200 miles or so without blowing out?? :D The number one cause of tire blow outs is underinflation so i'm worried about underinflating them to much and boom there goes my $250 tire :eek:
Old Oct 8, 2003 | 08:30 AM
SmoothFRC's Avatar
SmoothFRC
I had the SAME problem.. I actually hated driving on the highway with the DR's and i also did not want to drive with the lower psi...
It seems to be better under 30psi.. i am still hesitant at driving at 25, so i will deal with whatever wobble i have left at 28.
Old Oct 8, 2003 | 08:56 AM
bglmn's Avatar
bglmn
...it's just a totally different tire. Take it easy for a while...
you'll get use to them. :cheers:
Old Oct 8, 2003 | 11:50 AM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
I guess it should be mentioned, that although you can drive on the street with those DR's, they're usually considered to be a tire that is used at the track, and then switch back to more of a road handling tire, KD's, or Nitto Extremes for the street when you return. :eek: Just a thought. ;)
Old Oct 8, 2003 | 11:51 AM
Cobra Skinner
Default Re: BFG DR Problem Please help (bglmn)
I know I know guys.. with time I'll get used to it... The passengers in my car though will be poopin' a brick lol... A 50k car that wobbles outstanding... Anyways will the tire blow at 28 psi for a 200 mile trip? Is it risky and stuff? Still haven't gotten that answered
Old Oct 8, 2003 | 12:50 PM
Redvette_22's Avatar
Redvette_22
This is the same problem that "Mikie C" had when replacing his 315/17 with 315/18's. The sidewall seems to be softer for better "reaction" on the starting line at the track, but you will get the "sway" with it. There is no known correction for it, it is something that you will have to get used to. It's almost easier to race on ET Streets then on these new 18" tires....but they do hook at the track....it may be an "undesireable" trait for them.
Old Oct 8, 2003 | 01:09 PM
Dope's Avatar
Dope
Resident moron
I do 100 mile round trips to my track at 25psi or less, never a problem. Remember, as they heat up the pressure with rise anyway. I'd start with 25 cold.
Dope
Old Oct 8, 2003 | 03:15 PM
SvenOdin's Avatar
SvenOdin
Default Re: BFG DR Problem Please help (Dope)
I ran a pair for a couple months this summer (315/30/18) and had them @28psi. Drove to Houston and back with no problems (over 300 miles round trip).
Old Oct 8, 2003 | 04:51 PM
2001 Red Coupe Bandit's Avatar
Default Re: BFG DR Problem Please help (SvenOdin)
I have the same ones and drive all the time on them. I put 25-27 in the rears. At 25 your low pressure sensor won't go off all the time.
Mine isn't a daily driver and I have a mean TC 3600 2.5 str. I like these tires and don't notice much float in just regular driving and so far I have pulled a 1.70 60' and a 7.58 at the track.
The Bandit.......... :cheers:
Old Oct 8, 2003 | 04:52 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Was 28psi cold or after they fully warmed up?
Also BANDIT,
When you say 25 to 27, i assume your mean cold tire pressure?
[Modified by MTI 427 Roadster, 3:54 PM 10/8/2003]
Old Oct 8, 2003 | 05:14 PM
SvenOdin's Avatar
SvenOdin
Default Re: BFG DR Problem Please help (MTI 427 Roadster)
Cold. This was the pressure I ran for on the street.
Never saw them get higher than 30 except when I made my trip to Houston. Got up to 32psi then, but wasn't a problem as IH-10 from S.A. to Houston is mostly flat and straight!
[Modified by SvenOdin, 4:16 PM 10/8/2003]
Old Oct 8, 2003 | 05:36 PM
Mine is 25, 26 in the rear after they are warmed up! these are really soft and if you over fill them they will not last as long. They will only last (so I am told) about 5K depending on how much you go to the track.
Gary :D
To BFG DR Problem Please help
Old Oct 8, 2003 | 11:16 PM
C7GrandSport's Avatar
C7GrandSport
Default Re: BFG DR Problem Please help (2001 Red Coupe Bandit)
28 PSI for the street works for me.
Old Oct 8, 2003 | 11:48 PM
BlackSun!'s Avatar
BlackSun!
Default Re: BFG DR Problem Please help (c5grandsport)
:iagree: :iagree: :thumbs:
Old Oct 10, 2003 | 08:17 AM
Cobra Skinner
Default Re: BFG DR Problem Please help (BlackSun!)
Awesome guys thats alot.. I'm going to put 25 psi in them cold and they'll warm up on the drive hopefully less wobble will occur :hurray:
