"Reduce Engine Power" No AC?? Help Guys
I was doing an idle relearn after I reinstalled my air intake system(air leak). When I started the car the car started hunting for idle and then went into reduce engine power. So I turned off my car and cleared my ipc codes. But now my cars AC(dual air zone) is not blowing any air. The console is turning on but the fans are not. I tried clearing the ipc codes and disconnecting my battery but no success. I also checked #24 fuse but it looks ok. What do you think could cause my AC fans not to turn on?
