Coil Overs....
Are there any other coil-over alternatives to the Mid-America kit?
Thanks in advance for any info.
:cheers:
I'm using a similar setup but it's a Ohlins setup and that is a completely different story :D
:cheers:
[Modified by vette.se, 8:50 AM 10/9/2003]
What is the difference between the LG one and the set-up you're using? I really do NEED to perfect the handling of my car - if I can't get it set up so that it's 100% (sometimes I'm scared the backend is gonna kick out and kill me!), as if I can't, I may have to say "bye bye" to my vette....
Any info, as always, much appreciated.
:cheers:
My setup have similar heim-joints in the top and bottom but are built around Ohlins 46HRC 2-way adjustable(compress and rebound) coilover. This setup is special built for my car so you can not buy it as a 'kit' from Ohlins. I make them on special order at $5900 and they can be found in my webshop but they are overkill if your not serious into roadracing.
:cheers:
My car seems to suffer from body-roll and a very twitchy back end - as you can see from my list of current mods, I have attempted to fix this, but without the required amount of success (it has improved, but not enough) - in your opinion, will the coil-over conversion fix this?
:cheers:
If you want the ultimate the LG is it. I got my DRM from a forum member at a discounted price otherwise I would have gone w/ the LG.
Stay w/ the DRM or the LG these have the Bilsteen sport w/ heavy duty threaded aluminum shock body. You can also choose spring rate to fit your need.
[Modified by boblackhardtop, 7:10 PM 10/8/2003]
I had the opportunity to go for a ride in Lou's FRC when I dropped off and picked-up my car back in Aug. The first comment/observation out of mouth was , "What suspension are you running??"
[Modified by SvenOdin, 5:26 PM 10/8/2003]
:cheers:
A) you can try to adjust the air pressures of the rear tires (probably more pressure)
B) you can stiffen the front end with more roll bar
C) you can raise the front or lower the rear (a little--like 0.1") to find the balance point the current spring/rollbar package wants. Lookup "roll couple distribution"
If you are talking about accelerative cornering (70%+ throttle) then you need to be looking for more grip at the rear:
A) wider tires in rear
B) stickier tires in rear
C) more front roll bar
D) roll couple distribution adjustment
Be sure to get the tires fully up to temperature (180dF-200dF) before making critical balance changes to the car. A pyrometer and a race track will help you get into the right ballpark.
I'm using GM T1 bars front/rear and 475lbs springs in front and 600lbs springs in rear with my coilovers. This is on DRM's recommendation.
I had the DRM coilovers with the above swaybar/coils before I changed to the Ohlins and I agree with boblack, they are awesome. The only problem I had with the DRM's is that the top bushing tends to brake at hard use. Going with the LG's or similar with heim-joints you get rid of this problem.
:cheers:
[Modified by vette.se, 8:59 AM 10/9/2003]
If so, how difficult are they to remove?
:cheers:
