ARE's Silver-Z C5R 422 Nitrous Motor is for sale. The BEST of the Best Parts used! It will be freshened up with Rings, Bearings, check spring pressures, all maintenance needed and all machining neccesary. The motor will be 100% like new. The motor has run 8.54@168 MPH in a 3240 lb car. This high compression engine is for race use only, not street.
C5R heads with Del West Titanium Valves ~380/265 cfm
ARE Custom Cast Runner/ Sheetmetal Box Intake
TNT Direct-Port Fogger
ARE BigBore ReSleeved LS6 Block
Lunati 4.00" Crank
Ross Racing Pistons
Jesel Belt Drive
Jesel Titanium Lifters
Jesel Mohawk 1.7 Shaftmount Rockers
Comp Cam Solid Roller Camshaft
External Race Oil Pump
Custom Wet Sump Rotating Pickup
Custom Oil Pasages
C5R Valvecovers
Complete Engine Blueprint/Buildup Sheets
$20K USD
Call the shop at 905-420-9195 and talk to Wade.
