Piston compression when changing brakes?
Old Oct 9, 2003 | 03:02 PM
Midwayman's Avatar
Midwayman
Default Piston compression when changing brakes?
When changing breaks on the vette, do you need anything special to compress the pistons?
Old Oct 9, 2003 | 03:11 PM
Patches's Avatar
Patches
Default Re: Piston compression when changing brakes? (Midwayman)
6" C-clamp and a piece of wood does it for me. :yesnod:
Old Oct 9, 2003 | 03:13 PM
Karl_in_Chicago's Avatar
Karl_in_Chicago
Nothing special - some guys just use channel locks or similar. I use a C-clamp and place one of the old pads up against the pistons. I also have speed-bleeders installed and loosen them so that when the piston is compressed the fluid in the caliper is pushed out of the system rather then back up towards the master cyl.
Old Oct 9, 2003 | 03:14 PM
JakeL's Avatar
JakeL
Default Re: Piston compression when changing brakes? (Patches)
:yesnod:
(just so you know he ain't :crazy:. ;) )
-Jake
Old Oct 9, 2003 | 03:50 PM
jackmott's Avatar
jackmott
Default Re: Piston compression when changing brakes? (JakeL)
if you are hardcore like me, you can just press them in with your hand =)
youll be sore the next day tho!
Old Oct 9, 2003 | 03:54 PM
JakeL's Avatar
JakeL
Default Re: Piston compression when changing brakes? (jackmott)
End up walking a little gingerly the next day then, huh? :D
-J
Old Oct 9, 2003 | 05:12 PM
90 droptop's Avatar
90 droptop
Default Re: Piston compression when changing brakes? (Karl_in_Chicago)
:iagree:
Thats the correct way to do it. Keep all that nasty crap out of your ABS system.
[Modified by 90 droptop, 2:13 PM 10/9/2003]
Old Oct 9, 2003 | 11:26 PM
KingTut's Avatar
KingTut
Default Re: Piston compression when changing brakes? (90 droptop)
Service manual says to take the cover off the brake fluid resevore and then it is pretty easy to do even with just your hands.
To Piston compression when changing brakes?
