GMPP LS6 Head Flow Numbers.
Old Oct 10, 2003 | 09:36 PM
Greg_E's Avatar
Greg_E
Default GMPP LS6 Head Flow Numbers.
I had my GMPP ls6 heads flowed at a local engine builder. The heads had some additional work done in the bowl by the previous owner and the exhaust ports have been hand sanded. I opted not to have the intake runners sanded, and valves are stock. The cam I will be using has .573/.580 lift Her are the numbers. Comments please.
Superflow SF-600. Tested @ 28" H20. No manifold.
Intake Exhaust
.200 150 116
.300 222 158
.400 261 189
.500 282 214
.600 291 218
Old Oct 10, 2003 | 09:59 PM
SpinMonster's Avatar
SpinMonster
Default Re: GMPP LS6 Head Flow Numbers. (Greg_E)
If they aren't mounted yet I would sent them out for a bigger valve (2.02/1.57). It will not require new seats and you will get a fresh multi-angle valve job. Use undercut valves for more flow. You will be able to sell the LS6 stockers. With a big cam and these heads you will benefit a lot from gearing.
Old Oct 10, 2003 | 10:23 PM
Greg_E's Avatar
Greg_E
Default Re: GMPP LS6 Head Flow Numbers. (SpinMonster)
How much are we talking for the larger valves and installation? The heads we're bought second hand but have never been installed. I was trying to keep this somewhat low budget. I probably woud have chosen a set of stage II heads if I was going to spend the extra cash and with that additional mod I would probably be up to or over that price. (With a set of heads that have already been milled .055") . I'm not sure it would be worth it at this point. Thanks for the reply!
[Modified by Greg_E, 10:26 PM 10/10/2003]
Old Oct 10, 2003 | 11:53 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
I have the GMPP LS6 heads with 2.02/1.57 valves.These heads are milled 0.055 " at the time of CNC by LPE. Combustion chambers are 58.5 cc.Intake runners are large at around 240 cc. Here's a link to my before and after flow numbers . Before is as received from Scoggin Dickey. After is with new 2.02 and 1.57 REV valves and additional hand-sanding by LPE. http://img.villagephotos.com/p/2003-...ngenfelter.GIF. They flow well. With test pipe I believe. :yesnod: :thumbs:
[Modified by binksZ06, 11:54 PM 10/10/2003]
Old Oct 11, 2003 | 12:37 AM
J-Rod's Avatar
J-Rod
Default Re: GMPP LS6 Head Flow Numbers. (binksZ06)
SDPC found in testing that adding bigger valves did not help flow at all in fact in some cases it hurt the heads.
Old Oct 11, 2003 | 02:27 AM
kh24's Avatar
kh24
Greg those heads flow well enough for the cam that you are using. Just make sure it is tuned properly and you should be very happy with your results.
Old Oct 11, 2003 | 08:48 AM
Greg_E's Avatar
Greg_E
Default Re: GMPP LS6 Head Flow Numbers. (kh24)
I was hoping to see slightly better flow numbers @ .500 and up but they will be OK for what I'm doing. I compared the numbers to those posted from SDPC and MTI, in J-Rod's spreadsheet, and mine for the most part are as good or slightly better. Thanks to everyone that repied :cheers:
To GMPP LS6 Head Flow Numbers.
