Let's talk Knock Retard
Old Oct 14, 2003 | 10:05 AM
tabbruzz's Avatar
tabbruzz
Default Let's talk Knock Retard
I would like some input regarding KR. I get upto 8 degrees of KR at WOT. Typically it's 2-4 degrees with your occasional 6-8 degrees. It seems to happen at WOT and upon Decelaration. I think it maybe false knock, but I'm unsure. I did an autotap in case anybody is interested in reading that. My LTRMs and 02s seem fine. My mods are listed below....Any help would be greatly appreciated......Tony
Old Oct 14, 2003 | 10:09 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Let's talk Knock Retard (tabbruzz)
You only get the bad KR while decelerating?? I have never seen that one before! :confused:
I take it that it must be false knock if you dont even have your foot in the gas and its detonating while slowing down.
The best solution is to get some 110 octane unleaded race fuel and head out with your Autotap and see if you can still get it to knock. This will let you know for sure if it is false or not.
[Modified by MattG, 10:10 AM 10/14/2003]
Old Oct 14, 2003 | 10:25 AM
tabbruzz's Avatar
tabbruzz
Default Re: Let's talk Knock Retard (MattG)
Matt,
The 8 degrees is at WOT. I get about 1.8 or so when decelerating....
Old Oct 14, 2003 | 10:26 AM
TopCat's Avatar
TopCat
Is it safe to run that high an octane in a street car? I'd heard that higher octane not only equates to knock resistance but flame / combustion temperature. Could mean burned valves, if I recall correctly (and it's fully possible that I don't remember correctly since it's been 15 years :jester )
Old Oct 14, 2003 | 11:17 AM
MattG's Avatar
MattG
Default Re: Let's talk Knock Retard (TopCat)
110 octane wont hurt your engine as long as it is UNLEADED. I wouldn't recommend running it all the time in your street car, but for a test to check for KR, you would be fine.
To Let's talk Knock Retard
