tire spinnn
Old Oct 14, 2003 | 10:50 PM
kewlpapaw's Avatar
kewlpapaw
Default tire spinnn
no traction at drag strip have bfg air pressure from 30psi to 15psi help :confused:
Old Oct 14, 2003 | 11:00 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: tire spinnn (kewlpapaw)
How are you heating them up? Are you driving thru the water? What setup are you running? How is your track prepped? Auto or stick? SCOTT
Old Oct 14, 2003 | 11:04 PM
gojo's Avatar
gojo
I found mine to spin unless they were really heated. The line lock was the difference. Don't go in the water. It gets in the treads and you will lose traction.
Old Oct 14, 2003 | 11:28 PM
kewlpapaw's Avatar
kewlpapaw
have magna charger 2800stall 342gear drive around the water tried heating them up in 1st then tried from 1st to 2nd no change in 60ft :confused:
Old Oct 14, 2003 | 11:32 PM
gojo's Avatar
gojo
If your not getting lots of tire smoke they're not sticky.
Old Oct 15, 2003 | 06:56 AM
kewlpapaw's Avatar
kewlpapaw
thanks for the info ill try it again on friday
Old Oct 15, 2003 | 07:20 AM
kumar75150's Avatar
kumar75150
With drag radials, I would suggest going through the water.
Otherwise, doing a dry burnout is asking for your rear end to break.
Old Oct 15, 2003 | 01:17 PM
gojo's Avatar
gojo
Default Re: tire spinnn (kumar75150)
The tracks I go to, will not let anyone with treads in the water. It really screws up the starting line.
Old Oct 15, 2003 | 06:34 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: tire spinnn (jfpilla)
I have the BFG's also and can't seem to get better then a 2.1. It is better then the 2.4's I was getting. I guess I need to warm them up better. Kaley
To tire spinnn
