Burnt spot on brakes
Old Oct 15, 2003 | 03:39 PM
BigBlue's Avatar
BigBlue
Default Burnt spot on brakes
After so spirited driving, I looked at the brakes and I noticed that they have burn marks all over them. Now I don't know if this was ABS kicking in or not (I couldn't feel it if it was) but it's got me kinda worried. I didn't slam on the brakes either. That's why I don't think it was ABS. I was very smooth and only pushed the pedal in about half way. The car is smooth as silk and there's no steering wheel jerk while driving to indicate a warped rotor and there's no pedal pulsation to indicate a warped rotor.
Old Oct 15, 2003 | 04:57 PM
silverz06vette's Avatar
silverz06vette
Default Re: Burnt spot on brakes (BigBlue)
Have a look at this:
http://www.stoptech.com/whitepapers/...otors_myth.htm
Old Oct 15, 2003 | 05:10 PM
VetteDrmr's Avatar
VetteDrmr
My guess is that you just got some brake pad deposits on the rotors. I autocross with mine reasonably frequently, and I've never had a warpage problem. Also, my rotors have the same dark markings you're describing.
If there's no sign of warpage, I don't think you've got a problem.
HTH, and have a good one,
Mike
Old Oct 15, 2003 | 05:37 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Holding the pedal down (like at a stoplight) after heavy braking can cause problems. Try to let the brakes cool down (slow driving) before coming to a complete stop if possible. Also, the emergency brake will hold the pads against the rotor too, so don't use it after spirited driving.
Old Oct 15, 2003 | 05:42 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Burnt spot on brakes (SDVette)
The Emergency brake has nothing to do with the pads... the ebrake system is a drum and shoes system... No pads are engaged to the rotors with the emergency brake.
Old Oct 15, 2003 | 06:16 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: Burnt spot on brakes (Evil-Twin)
:iagree:
Old Oct 15, 2003 | 06:24 PM
SDVette's Avatar
SDVette
I thought the rear calipers were engauged by the e-brake?
Old Oct 15, 2003 | 08:08 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Nope, it's an internal drum type system.
Old Oct 15, 2003 | 08:14 PM
Patches's Avatar
Patches
Below is a pic of mine with the rear rotor off. That's the e-brake assy. just as E.T. described it. :yesnod:
Old Oct 16, 2003 | 12:37 PM
SDVette's Avatar
SDVette
Default Re: Burnt spot on brakes (Patches)
I stand corrected! Thanks for the pic!
Old Oct 16, 2003 | 03:05 PM
Duck916's Avatar
Duck916
The advice about not using the parking brake is correct, however, for most cars as most cars do not have a separate braking surface for the parking brake. Good advice, just not applicable here.
To Burnt spot on brakes
