How to install front screens
Old Oct 15, 2003 | 09:28 PM
John D.'s Avatar
John D.
Default How to install front screens
Just picked up a pair of front screens for me 1999. Has anyone ever installed these?
These are to larger ones for the opening where the fog lamps are. They look to have a mounting screw hole?
Any ideas out there.
P.S. These are factory GM parts. :chevy :seeya :flag
Old Oct 15, 2003 | 09:38 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: How to install front screens (John D.)
Go to Home depot, get some heavy duty adhesive backed velcro, cut into a few 1" wide strips, stick it to the sides of the screens (have both sides of the velcro attached to each other).
Clean the openings on the car with rubbing or denatured alcohol to remove any dirt or wax, let dry. Then remove the adhesive backing from the other side of the velcro (which is stuck to the velcro you stuck on the screen already) and press the screen in place in the opeining.
They are bolted in place on Z06's...but this method is much easier, is easily removable, and works.
:cheers:
Old Oct 16, 2003 | 07:23 AM
John D.'s Avatar
John D.
Default Re: How to install front screens (Y2Kvert4me)
Thank you for the help.
Old Oct 16, 2003 | 02:00 PM
andreas g.'s Avatar
andreas g.
I called west coast corvette and asked. Thet told me to get two way indoor outdoor tape. It worked great. No problems not even in the rain.
[Modified by andreas g., 7:01 PM 10/16/2003]
Old Oct 16, 2003 | 03:54 PM
FO SHIZZLE's Avatar
FO SHIZZLE
:cheers:
Place a piece of paper betwwen the velcro , align the screens and then pull out the paper :thumbs:
Old Oct 17, 2003 | 11:05 AM
carpe dm's Avatar
carpe dm
John: You can use "velcro" as many have, or you can use 3M double sided tape. I used the tape and it work well. I also removed the OEM plastic fillers before installation, for more air flow. :yesnod: :)
Old Oct 17, 2003 | 01:52 PM
SteveL4446's Avatar
SteveL4446
:cheers:
:iagree: The only thing I can add is - Once you get the velcro stuck in place on both the car and the screen, lay a piece of note book paper over the velcro before you slip the screen into place. That way once you press the screen ito place, you just pull out the paper and the two pieces of velcro connect right up. Makes the install really easy. :thumbs:
Old Oct 17, 2003 | 06:35 PM
Use Velcro. Makes it easy to put on and easy to take off for cleaning.
To How to install front screens
