stock ls1 cam specs ?
Old Oct 16, 2003 | 02:03 PM
TVSKIP's Avatar
TVSKIP
Default stock ls1 cam specs ?
I'm in the process of deciding on a new cam, but before I do, just curious if anyone has the specs on the factory 2000 Corvette ls1 cam? Lift, duration and Lsa would be great. Thanks everyone for a great forum. It is always helpful. :flag SAVE THE WAVE!
Old Oct 16, 2003 | 02:17 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: stock ls1 cam specs ? (TVSKIP)
Here is a competive spec analysis on the 2001 LS1 vs the Z06
http://corvetteactioncenter.com/specs/z06/ls1ls6.html
:cheers:
Jeff
Old Oct 16, 2003 | 05:32 PM
C5BTW's Avatar
C5BTW
The specs for a 1997-2000 C5 LS1 cam are as follows:
- Intake / Exhaust Duration @ .050" Lift: 202 / 210 Degrees
- Intake / Exhaust Lift: .472" / .479"
- Lobe Separation Angle: 117 Degrees
The specs for a 2001-2004 C5 LS1 cam are as follows:
- Intake / Exhaust Duration @ .050" Lift: 199 / 210 Degrees
- Intake / Exhaust Lift: .467" / .479"
- Lobe Separation Angle: 116 Degrees
To stock ls1 cam specs ?
