front end pop
Old Oct 16, 2003 | 10:31 PM
torched you's Avatar
torched you
Default front end pop
00 frc 16K mi i took my front bolts out about 2 weeks ago and havent drove the car much may be bout 5-8 hours total the past 2-3 days i notice a pop when i turn the wheel is this cause i took the bolts out ? :confused:
Old Oct 16, 2003 | 11:36 PM
torched you
Default Re: front end pop (torched you)
no one else have the prob i guess :)
[Modified by torched you, 11:36 PM 10/16/2003]
Old Oct 17, 2003 | 02:32 AM
stngh8r's Avatar
stngh8r
i'm with ya. I have something similar to that. I dont notice it all the time and its not real noticeable anyways, but sometimes more than others. I also am looking for answers. Somebody has to know.
thanks
eric <><
Old Oct 17, 2003 | 10:50 AM
carpe dm's Avatar
carpe dm
Have you checked the clearance of your tires, brake lines, etc. Something may be touching, or hanging up, when you turn the wheels. Have you had an alignment done? :rolleyes: :confused:
Old Oct 17, 2003 | 12:32 PM
Avanti's Avatar
Avanti
I've left side pops, etc. on a '01 with 17K (no lowering) that come and go--more come of late. Seems to be both front and back, and I've checked everything for tightness and apparent wear, etc. Almost sounds like a brake pad shifting sometimes but not limited to brake use situations.
I really, really am putting off going to the dealer! A friend just had to fight a battle to get a minor correction made on his new '04 there! No other one any better around the sticks where I live. Pitiful state of affairs.
Any thoughts, any one? Thanks.
Old Oct 17, 2003 | 12:40 PM
Traffic Hater's Avatar
Traffic Hater
Default Re: front end pop (Avanti)
I have had the same problem with my 2002 coupe for 2 years and 25,000 miles. It's not the calipers. I've had them taken off the car and checked along with using the correct torque.
I just had my endlinks replaced by the dealer aliong with an alignment. It seemed to do the trick. I don't even known what end links are, but they replaced the front ones. I think it they were the cause.
It's that pop sound when you trun the wheel going into a parking spot. Slow speeds only! Mine also happened when I would brake backwards?
Again, my problem was helped by replacing the endlinks. The dealer made that determination for me :leaving:
I hope this helps!
Old Oct 17, 2003 | 06:42 PM
torched you
Default Re: front end pop (Traffic Hater)
well im going later to look underneat and check some stuff out it only does when i turn the wheels from lock to lock and kinda pops at the end of each turn i might put my front bolts back in and see if that does anything and no i haveint had the car line'ed up yet thanks guys :cheers: :cheers: :cheers:
:steering:
:steering:
Old Oct 17, 2003 | 06:56 PM
Pipes's Avatar
Pipes
Same here, let us know if you find anything. :lurk:
Old Oct 17, 2003 | 07:54 PM
Avanti's Avatar
Avanti
Traffic Hater:
Thanks for the suggestion... but, put on new aluminum end-links and it made no difference.
I guess when something falls off or I can't stand it any longer I'll drag it into the dealer. It's potentially their problem for another gazillion miles and 4.5 years.
Glad you found your noise and corrected it. :yesnod:
Old Oct 25, 2003 | 01:31 AM
torched you
:steering:
:steering:
well i put the front bolts back in and its fine now but on the way to garage my rear end also made a pop sound the dic said service abs - active handlein - tc
:eek: :cry so i looked under the car everything looked good so when i got back in the car everything was fine all the lights went off so i had to rasie the back up a lil bit to been fine ever since i think the car was just to damm low lol but it looked so good but o well id radther be ridein a lil higher then have my car poping all over lol
To front end pop
