Why do coated TPIS headers rust?
Old Oct 17, 2003 | 08:44 AM
skidmarc's Avatar
skidmarc
Default Why do coated TPIS headers rust?
I have TPIS headers and my car is mostly in the garage...never in the rain....so why would the headers rust in less than a yr? It is just surface rust...so I am wondering if it can be neutralized without adversely affecting the jet hot coating????
Anyone else have this problem????
Old Oct 17, 2003 | 08:53 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Why do coated TPIS headers rust? (skidmarc)
I've got TTS headers. The rust is just mainly due to any dirt/moisture that was trapped or cought in the coating process, and the heat from the headers creates a expanding zone, so to speak, for the moisture and eventually you get the little rust spots.
Stainless steel headers or recoating is about the only recourse. If I could do it again, would probably goto stainless steel works or LGM headers.
Old Oct 17, 2003 | 09:28 AM
skidmarc's Avatar
skidmarc
Default Re: Why do coated TPIS headers rust? (JoeyG)
so the rust is under the coating?
Thanks for the info!
Old Oct 17, 2003 | 11:07 AM
wwashing's Avatar
wwashing
IMO. Crappy coating job. The headers where not properly prepared for coating!
Old Oct 17, 2003 | 11:43 AM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: Why do coated TPIS headers rust? (wwashing)
:iagree: I don't have any problems with my TPIS headers. There must not have been proper preparation before coating yours.
- Mark
Old Oct 17, 2003 | 12:04 PM
gojo's Avatar
gojo
Is it possible that it's only the water from your A/C oxidizing on the surface of the header?
Old Oct 17, 2003 | 05:10 PM
Dope's Avatar
Dope
Resident moron
Coated mild steel will rust.
I had FLPs before - the collectors were completely bare and rusted in a little over a year. It was driven in rain/snow though.
My vette, almost never sees rain, never snow, and my TPIS headers have the coating coming off/rusting off at the bottoms of the ends of the collectors (where the mid-pipe connects). They have maybe 6k miles on them.
If you want something that doesn't rust, get some coated stainless headers.
Don't listen to anybody who says they won't rust, because they will.
Dope
Old Oct 17, 2003 | 05:25 PM
GENERAL ST's Avatar
GENERAL ST
Default Re: Why do coated TPIS headers rust? (Dope)
dope is not a dope.. theyll rust!!! :seeya :chevy :cheers:
Old Oct 17, 2003 | 05:57 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Why do coated TPIS headers rust? (GENERAL ST)
LG's coatings on anything fail is just a matter of how long. Scratch them putting them in and there's the break.
[Modified by John Shiels, 5:57 PM 10/17/2003]
Old Oct 17, 2003 | 06:22 PM
robsvette's Avatar
robsvette
:lolg: :lolg: :lolg:
Old Oct 17, 2003 | 09:05 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Why do coated TPIS headers rust? (robsvette)
JoeyG; that's one bad azz sig pic you have. I guess I need to lower my pewter coupe too!
:cheers:
Old Oct 18, 2003 | 08:57 AM
vstella's Avatar
vstella
Huh... :rolleyes: That's news to me. I've had the TPIS for over two years ..No problems here :thumbs:
Old Oct 18, 2003 | 11:24 AM
90 droptop's Avatar
90 droptop
Default Re: Why do coated TPIS headers rust? (vstella)
:iagree:
Old Oct 20, 2003 | 08:36 AM
skidmarc's Avatar
skidmarc
I will have to find out about the warranty of these LT's! Anyone know???
Old Oct 20, 2003 | 08:57 AM
JoeyG's Avatar
JoeyG
Default Re: Why do coated TPIS headers rust? (Mike Mercury)
Thanks for the kind words Mike.
As far as the rusting issue, the manufacturer will probably only tell you that it's not really thier fault, but for a service fee you can have them stripped and recoated. :rolleyes:
Old Oct 20, 2003 | 10:06 AM
skidmarc's Avatar
skidmarc
do you know what the time frame is for re-coating? fee?
thanks for the info!
Old Oct 20, 2003 | 02:46 PM
JoeyG's Avatar
JoeyG
You'd have to contact TPIS directly, probably.
Old Oct 21, 2003 | 08:27 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have a little issue with my DS header..............this is NOT FROM THE AC discharge and you can see the scratch marks I touched up prior to firing up after the install. No rust in the scratch marks, but below :eek:
The PS is fine
Usually inproper prep for the coating/thin coating application is the reason for this.
The vendor I bought these from is looking into it.....less than 1 year on an EDD.
I will sand & put some hi-temp on just like the scratches :thumbs:
Old Oct 21, 2003 | 09:49 AM
skidmarc's Avatar
skidmarc
Default Re: Why do coated TPIS headers rust? (ALLTHROTTLE&NOBOTTLE)
thanks for the input...I will contact TPIS and post what they have to say/can do for me.....I am thinking of having em recoated when I have the Intercooled Magnusen installed(when its available.....hopefully December)!
To Why do coated TPIS headers rust?
