It could be a bad wire, or a bad plug. Most likely, though, is a wire that is (was) not completely connected. Make suren they are fully seated on both the coils and the plugs.
I see you lowered your fan temps, so I am assuming you have a programmer of some sort.....have you tried going back to stock and then reloading the program??? Had to do this before when the car "got lost". Fixed it for me :seeya
the stock program was reloaded...still no good...I will have to check the coils......what is the correct Idle Re-Learn procedure?? I here many different variations...???? :confused:
Idle relearn - turn key to ON. Pull fuses 16 and 23 under the hood. DIC will indicate ABS error and you should hear a ding or two... Turn key off, reinstall fuses, start car and let it idle until it reaches proper operating temp. Drive for 30-50 miles varying speed and gears, etc. Should be all there is to it - just did it myself over the weekend.
