LS6 Intake Manifold Upgrade. MAP sensor replacement required?
Old Oct 18, 2003 | 09:11 AM
Greg_E's Avatar
Greg_E
Default LS6 Intake Manifold Upgrade. MAP sensor replacement required?
I read somewhere that the MAP sensor needs to be replaced when doing the LS6 intake manifold. In all of the posts I have read on this subject, I don't remember anyone saying they had to replace the sensor. Are the sensors different for a '99 LS1 intake and the 2001 and up LS6 intake? I guess it would make sense that the measured MAP could be different due to the different design of the manifold and may be calibrated differently. Thanks. :confused:
Old Oct 18, 2003 | 11:38 AM
MTWallet's Avatar
MTWallet
Default Re: LS6 Intake Manifold Upgrade. MAP sensor replacement required? (Greg_E)
New LS6 Intakes come with a new MAP sensor installed already. Just bolt it on and go!
Old Oct 18, 2003 | 12:00 PM
FRC sexi blk's Avatar
FRC sexi blk
N
I do believe the MAP sensor is inside the manifold somwhere, no need to replace it. I hope you are not talking about the MAF? No need to replace that either. LS6 manifold is a direct bolt on. make sure you have the coolant re-route line kit if you do not want to do a little grinding.
Old Oct 18, 2003 | 04:40 PM
MTWallet's Avatar
MTWallet
Default Re: LS6 Intake Manifold Upgrade. MAP sensor replacement required? (cute301guy)
The MAP sensor is located on the rear of the intake and fits in a round socket, kind of like how a headlamp bulb is installed..
You can see it here in this picture: (click to enlarge)
[Modified by MTWallet, 3:42 PM 10/18/2003]
Old Oct 18, 2003 | 04:42 PM
Greg_E's Avatar
Greg_E
Default Re: LS6 Intake Manifold Upgrade. MAP sensor replacement required? (MTWallet)
Thanks. Somewhere, I found a list of parts needed to do the swap and the MAP (Manifold Air Pressure) sensor and gasket were on the list of parts. I didn't realize that the intake manifold already came with it installed. :thumbs:
Old Oct 18, 2003 | 04:45 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Are you talking about the LS6 Intake or just the 02 manifold. :confused: :confused: :withstupid: :troll
Old Oct 18, 2003 | 04:53 PM
Greg_E's Avatar
Greg_E
Default Re: LS6 Intake Manifold Upgrade. MAP sensor replacement required? (LittleBoyBlu99)
I'm pretty sure that all 2001 and up Corvettes came with the LS6 Intake manifold.
To LS6 Intake Manifold Upgrade. MAP sensor replacement required?
