From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Re: Z06 intake, more LS1 edit= 2 tenths. (Fastguy)
Changed the fuel trim.
Ok...This is Mag Red...and I'm a little slow.....so you are going to have to be a bit more specific here :D Let's say you you give me a for instance :lol: Like my fuel trims were XXXX before the install and after they were reading xxxxx so I went into the xxxxxx field and changed the fuel trims to XXXXX :lol: :seeya
Re: Z06 intake, more LS1 edit= 2 tenths. (LittleBoyBlu99)
i added ls6 intake last month with 28.8 injectors along with more ls1 edit tuning. i went from 12.18@112 to 11.88@114...also added around 16rwhp on the dyno.... :yesnod: :cheers:
BTW, on my third pass the sig pic was taken. My odometer rolled from 142,999 to 143,000 at half track.:D Going to run this thing until it quits, which doesn't seem to be anytime soon.
