Removing lock from glove box
Old Oct 19, 2003 | 12:05 PM
bbster's Avatar
bbster
Default Removing lock from glove box
Can someone tell me how to remove the lock from the glovebox handle.
Thanks....
Old Oct 19, 2003 | 10:38 PM
C7GrandSport's Avatar
C7GrandSport
Default Re: Removing lock from glove box (bbster)
Hey, bbster you're in the right section. I figured I'd give you a bump since I'd like to know the answer also!
Old Oct 19, 2003 | 11:12 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Assuming you have the handle out and on the table in front of you:
1. Insert your key into the lock cylinder
2. Turn key 1/4 turn clockwise (locked)
3. Release the retainer by poking a small tool, such as an eyeglass
screwdriver in the slot on the RH side of the lock. Keep pressure on.
4. Turn the key another 1/4 turn.
5. Pull cylinder out.
Old Oct 20, 2003 | 07:52 PM
bbster's Avatar
bbster
C5 StockSwap Many thanks for the reply Worked like a charm....
I love this forum..... :cheers:
Old Oct 20, 2003 | 08:30 PM
C5 StockSwap
Cruise-In V Veteran
My Pleasure! :cheers:
Old Oct 20, 2003 | 11:20 PM
C7GrandSport
Default Re: Removing lock from glove box (C5 StockSwap)
Thanks C5 StockSwap! Now I can put the red handle on the red glove box and the black handle back on the black box. Life is good.
To Removing lock from glove box
