Mallett Shifter
Old Oct 19, 2003 | 01:26 PM
Closer_2001's Avatar
Closer_2001
Default Mallett Shifter
What **** works with the Mallett shifter??
Old Oct 19, 2003 | 02:02 PM
wstory1's Avatar
wstory1
Default Re: Mallett Shifter (Closer_2001)
They come with a **** from Mallett. I believe they have a non-standard thread size. :rolleyes:
Old Oct 19, 2003 | 02:43 PM
Mike Siska's Avatar
Mike Siska
After I cut the top threads off (made it shorter also), I cut threads with a 9/16 x18 die and was able to put an MGW **** on it. I probably could have used any **** except the stock one.
Old Oct 19, 2003 | 03:29 PM
Monster231's Avatar
Monster231
Default Re: Mallett Shifter (Mike Siska)
Whats a Mallet shifter? :confused:
Old Oct 19, 2003 | 03:37 PM
Closer_2001
I guess it is too small for the stock ****?? Can you post a pic of your ****.
BTW: A Mallett shifter is a modified stock shifter made by Mallett cars - Supporting Vendor/Tuner
Old Oct 19, 2003 | 07:00 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Mallett Shifter (Monster231)
About $400 :rofl: :lolg: :lolg:
Old Oct 19, 2003 | 07:58 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Mallett Shifter (racer44)
$400.00 for a shifter? What is so special about them? If anything? kaley
Old Oct 19, 2003 | 09:38 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Default Re: Mallett Shifter (2C5only21)
I've seen and felt the Mallett, and they are really smooth between gears. It has a smaller "upside-down teardrop" handle on it, small for some, but very comfortable. No notchy feeling like you get with some aftermarket shifters (like I have). $400 is steep. Find someone who has one and try it out. You'll probably like it. Enough to spend $400? Up to you...
Old Oct 19, 2003 | 10:59 PM
Closer_2001
Only if you buy new :steering:
Old Oct 20, 2003 | 01:16 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
A lot of the aftermarket ***** have different sized inserts to accomodate. They may fit. :rofl:
To Mallett Shifter
