2001 Coupe 6sp. Cam spec. HELP!
Old Oct 20, 2003 | 02:57 PM
Gee3's Avatar
Gee3
Default 2001 Coupe 6sp. Cam spec. HELP!
I need the cam specs. for a stock 2001 6 sp. 350 HP 375 ft. lbs. Can anyone help find the specs?
Old Oct 21, 2003 | 12:03 AM
Avanti's Avatar
Avanti
Default Re: 2001 Coupe 6sp. Cam spec. HELP! (Gee3)
I've seen them here a couple years ago, both LS-1 and LS-6. Have you tried a "search?" Sorry, I don't recall them.
Old Oct 23, 2003 | 10:16 PM
Closer_2001's Avatar
Closer_2001
198/204 .500 @ .050
Old Oct 24, 2003 | 08:55 AM
C5BTW's Avatar
C5BTW
Default Re: 2001 Coupe 6sp. Cam spec. HELP! (Closer_2001)
My understanding is that the cam specs for 2001- 2004 C5's with both manual and automatic transnission is as follows:
- Intake / Exhaust Duration: 199 / 210 Degrees @ .050 Lift
- Intake / Exhausr Lift: .467" / .479"
- Lobe Separation Angle: 116 Degrees
Automatic C5's make less torque (360 Ft Lbs) than manual C5's (375 Ft Lbs) due to "torque management" by the PCM that, among other things, reduces timing advance.
To 2001 Coupe 6sp. Cam spec. HELP!
