Do I want 17'' or 18'' Comp. DR
Oct 20, 2003 | 04:23 PM
What size do I want for the strip for back of a 02 Z06
17/295
17/315
18/295
18/315
Oct 20, 2003 | 04:37 PM
Re: Do I want 17'' or 18'' Comp. DR (z-u-later)
17/315s because you will have more sidewall....less sidewall will give you a stiffer tire and not hook as well.
Oct 20, 2003 | 06:34 PM
Re: Do I want 17'' or 18'' Comp. DR (kh24)
I am thinking of drag radials too. Why 17in as opposed to 18in?
Oct 20, 2003 | 09:30 PM
Re: Do I want 17'' or 18'' Comp. DR (EB20003)
If they make them in a 295/ 17" get it. Over sized tires on rims don't hook as good. The tire cups in the middle if tire pressure is low. I run a stock aftermarket 17"/ 9.5 rim with the correct offset and the 275/40 17" Bite!
:thumbs: :cheers:
Oct 20, 2003 | 09:37 PM
Re: Do I want 17'' or 18'' Comp. DR (LittleBoyBlu99)
:yesnod: :iagree:
Oct 21, 2003 | 01:23 PM
Re: Do I want 17'' or 18'' Comp. DR (MC TORCH RED)
:yesnod: :iagree: :rolleyes: :rolleyes:
Oct 21, 2003 | 08:12 PM
St. Jude Donor '05
315X17 with 17X11 wheels!
Oct 21, 2003 | 09:15 PM
Cruise-In II & IV Veteran
CI VI Drag Champ!
I ran many races with 275/17 and 315/17. I found the 315 was a little more consistent.
Have not run with the 18" but have seen good results here.
Oct 21, 2003 | 09:25 PM
Re: Do I want 17'' or 18'' Comp. DR (REDGAR)
I had good results with the 315/35/17 on 17x11.5.
I've driven the BFG 315/30/18 on the street for a couple months this summer, but never had a chance to try them out on the strip. This will soon change as I plan on running the BFG 315/30/18 full-time, and anticipate hitting the track as often as possible now that the weather is cooling off here in Texas :D
Oct 21, 2003 | 09:58 PM
Are you guys using ZR1 17 inchers to mount up your D/R's? :cheers:
Oct 21, 2003 | 10:20 PM
CI VI Drag Champ!
Re: Do I want 17'' or 18'' Comp. DR (dads01dream)
I used ZR-1 11"s on a set of mine.
Oct 21, 2003 | 11:10 PM
Hey Redgar,
What's the backspacing for these? Did you use ZR-1's all the way around? :chevy
Oct 21, 2003 | 11:27 PM
For the track forget about drag radials,just go with the ET Streets.
Oct 21, 2003 | 11:28 PM
CI VI Drag Champ!
Sorry not sure of backspacing. I got pictures though. Mine were AFS repros.
http://www.corvettechallenge.info/C5zr-1wheels/
