optima yellow vs. red top?
Old Oct 21, 2003 | 12:05 AM
SLO VETTE's Avatar
SLO VETTE
Default optima yellow vs. red top?
i want to replace my stock gm unit. hear alot on the forum about optima yellow top and optima red top. what's the difference? thanks.
Old Oct 21, 2003 | 12:20 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: optima yellow vs. red top? (SLO VETTE)
A Yellow top is a deep cycle battery that can handle being discharged about 70% or more. It is normally used in a car with a high accessory load (like a big stereo).
http://www.optimabatteries.com/using...ionsYellow.asp
http://www.optimabatteries.com/using...cationsRed.asp
Old Oct 21, 2003 | 12:33 AM
SLO VETTE's Avatar
SLO VETTE
Default Re: optima yellow vs. red top? (rbartick)
thanks! which one should i get, yellow or red? and how much should i expect to pay, generally? i'll be going to pep boys tomorrow, would rather be armed with some good info beforehand...
Old Oct 21, 2003 | 12:38 AM
RussBt's Avatar
RussBt
Depends on your application. If your electrical load is stock than a Red Top is the one you want. If you have a heavy electrical load (like a Mega Watt stereo) than a Yellow top is the one.
You can probably get it cheaper at Summit or Jegs.
Old Oct 21, 2003 | 12:39 AM
SLO VETTE's Avatar
SLO VETTE
red top it is then. thanks! any idea what the model number for the red top is for our c5's? mine's a '99.
Old Oct 21, 2003 | 01:10 AM
Jimmy 2 Times's Avatar
Jimmy 2 Times
when i did my battery relocation, i used the red top, never had a problem with it, the battery you are looking for is group size 75, then just pick the CCA's that you want (i think there is 700 and 900 but im not sure)
Old Oct 21, 2003 | 01:31 AM
HIGHRPM's Avatar
HIGHRPM
Default Re: optima yellow vs. red top? (Jimmy 2 Times)
What is the model number for the Yellow Top? My battery is just about down to its last carnk. :cheers:
Old Oct 21, 2003 | 10:07 AM
SteveL4446's Avatar
SteveL4446
I just purchaced a red top (for my 2000FRC) at Pep Boys last night -- 120 bucks.
Size 34/78 (800CCA). Fit in perfectly. Had to "unlock" my stereo, and set the clock afterward- but that's it. :thumbs:
Old Oct 21, 2003 | 10:49 AM
RussBt's Avatar
RussBt
Part #s are listed on Optima's site. There are very few models. Your only options are two different CCA ratings and a side/top post option.
The red top is like $78 plus shipping at Summit & Jegs.
Old Oct 21, 2003 | 11:02 AM
Monster231's Avatar
Monster231
Im gonna order one now
Old Oct 21, 2003 | 12:58 PM
Cajun99's Avatar
Cajun99
I just switched from a Yellow to a Red this morning :cuss :cuss
Several days ago I noticed that when first starting the car it was turning over a little slower before firing up. The voltage gauge was slower in coming up and then would be charging in the high 14s to low 15s for several minutes. I have a new alternator and my yellow top was almost three years old so I had a feeling it was dying.
Got slightly cool here last night and sure enough...went to crank the car this morning and got the dreaded clicks but accessories were still working. :cry
Went and picked up a red top at AutoZone and all is well again. I went with the red because it has a three year warranty whereas the yellow was only a year. So far my big ole stereo system seems to not notice the difference.
I figure I got my money's worth out of the Yellow :D :cheers:
Old Oct 21, 2003 | 01:08 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: optima yellow vs. red top? (Cajun75)
I just bought a yellow top. I did this because sometimes my car sits for a few weeks. I think the deep cycle of the yellow will be better for this.
To optima yellow vs. red top?
