Traction Sys Active w/new wheels
Old Oct 21, 2003 | 10:49 AM
jamwme99's Avatar
jamwme99
3rd Gear
Default Traction Sys Active w/new wheels
I put four 18x9.5 Z06 style wheels on my 99 C5 but now the traction control system is activating during highway driving. I have been told the computer is programmed for a differential in front and rear spin rates and when they differ too much it activates the traction control. Is this true, can it be reprogrammed, does anybody have any recommendations? :confused:
Old Oct 21, 2003 | 10:58 AM
Monster231's Avatar
Monster231
Default Re: Traction Sys Active w/new wheels (jamwme99)
I have the same set up on my 98, and i have no probs. what type of tires are you running, I suppose if the pver all diameter of the wheel is alot bigger there will be a big difference
Old Oct 21, 2003 | 12:30 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The ABS module looks for a wheel speed variation of 6mph to detect a fault or activate the ABS,which wouldnt be from a 1" diameter tire difference...The best way to check would be to monitor wheel speeds with a TECH2 :yesnod:
Old Oct 21, 2003 | 02:41 PM
jamwme99's Avatar
jamwme99
3rd Gear
Default Re: Traction Sys Active w/new wheels (Monster231)
Goodyear Eagle F1 275/40/18 on all fours.
Old Oct 21, 2003 | 04:43 PM
Dope's Avatar
Dope
Resident moron
There's your problem. You need to have differing tire sizes, front to back. Try 275/40/18s on the rear and 275/35/18 on the front, that should do the trick.
Dope
Old Oct 21, 2003 | 05:02 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Traction Sys Active w/new wheels (Dope)
I run 25.3 diameter wheels front and rear and have no problem with T/C. I have used this wheel/tire combo on both my 97 and my Z06.
Bill
Old Oct 22, 2003 | 11:45 AM
jamwme99's Avatar
jamwme99
3rd Gear
What size tires do you have front and rear?
Old Oct 22, 2003 | 12:37 PM
Bill Dearborn
From playing around swapping wheels I have found out that T/C will cut in very quickly if the front tires are a larger diameter than the rears. In my case T/C applied the rear brakes while coasting down hill in nuetral.
Bill
To Traction Sys Active w/new wheels
