Differential output shaft ?
Old Oct 21, 2003 | 08:28 PM
PewterVette's Avatar
PewterVette
Default Differential output shaft ?
This may be a dumb question, but for future reference, what is required to install a heavy duty output shaft on a differential?
Thanks,
Adam
Old Oct 25, 2003 | 10:43 PM
warvette's Avatar
warvette
7th Gear
Default Re: Differential output shaft ? (PewterVette)
I'm in the same boat. I just got my heavy duty output shaft from LPE for my 3.73s (which I'm using for a coffee table at the moment.) I'm probably just going to take it to Central Chevrolet next week and let them do it if I can't figure out what I'm doing first.
Old Oct 25, 2003 | 11:31 PM
kumar75150's Avatar
kumar75150
Default Re: Differential output shaft ? (warvette)
You just have to apart the differential casing and put it in there from what I can remember. Takes a few minutes once you have the differential out of the car.
Old Oct 26, 2003 | 12:49 AM
SQEZN BI's Avatar
SQEZN BI
There should be no extra charge if you supply the axles they just put the new ones in instead of the old during reassembly. :D
To Differential output shaft ?
