2001, Cruise Control Won't Work
Old Oct 21, 2003 | 10:15 PM
Shortimer's Avatar
Shortimer
Default 2001, Cruise Control Won't Work
Can anyone suggest what I might check on my 2001 to restore the cruise control. It doesn't work. I've already checked the fuse and it's good. I'd like to look under the hood, in the engine bay, just in case there is a connection or relay, something of that sort. Otherwise, it's off the the dealer. :-(
Old Oct 21, 2003 | 11:00 PM
lazlojones's Avatar
lazlojones
Default Re: 2001, Cruise Control Won't Work (Shortimer)
Check the brake switch, try pulling up lightly with your toe and
see if it will turn on while you're doing this.
Old Oct 21, 2003 | 11:11 PM
Shortimer's Avatar
Shortimer
Default Re: 2001, Cruise Control Won't Work (lazlojones)
Thanks for the tip. I'll give it a try on Wednesday.
Old Oct 22, 2003 | 11:39 AM
Colbalt Blue's Avatar
Colbalt Blue
Take a look at you tail lights, including the third tail light. I read somewhere that if a tail light was out, the cruise control will not work.
To 2001, Cruise Control Won't Work
