Delco Battery and Battery tray question
Old Oct 22, 2003 | 01:12 PM
GashWagon's Avatar
GashWagon
Default Delco Battery and Battery tray question
Well, to my surprise I had one of the factory Delco batteries that the factory tightened the Pos cable too tight and cracked the battery case. It lasted 4.4 years. When I removed the battery, I of course found that the acid was dripping out for some time and the battery tray was full of growing acid crap! I cleaned as much as I could with baking soda and water, but wanted to remove the battery tray. I have a 1999 coupe. I found three bolts that were in the bottom of the tray kind of in a triangle hole and removed them but still the try would not come out. Does ANYBODY know how to get the tray out so I can clean under it (and also recover my 5/16 box wrench I dropped under the tray)?
Thanks in advance
Ron
1999 C5
State College, PA :cheers:
Old Oct 22, 2003 | 02:13 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Delco Battery and Battery tray question (GashWagon)
There are 4 bolts not 3,take a closer look :yesnod:
Old Oct 22, 2003 | 03:24 PM
GashWagon's Avatar
GashWagon
Default Re: Delco Battery and Battery tray question (C-5 TECH)
Hmmm 4 huh? I found the three that go into the side but never saw a 4th. Any idea where that 4th one is?
Ron :crazy:
Old Oct 22, 2003 | 04:04 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Old Oct 22, 2003 | 04:09 PM
GashWagon's Avatar
GashWagon
Wow, thanks. I can not believe there was a 4th bolt! I looked for 7 beers for another bolt!
Old Oct 22, 2003 | 04:27 PM
SFVetteman's Avatar
SFVetteman
Could be the law of diminishing returns taking effect :jester
Old Oct 22, 2003 | 04:33 PM
GashWagon's Avatar
GashWagon
Default Re: Delco Battery and Battery tray question (SFVetteman)
Yes, for sure! :iagree:
Old Oct 22, 2003 | 09:14 PM
RSVETTE's Avatar
RSVETTE
Well I'm not the only one who has lost
a wrench there....
I had to get a very strong light and a
magnet to get it out. :yesnod:
To Delco Battery and Battery tray question
