Removed trans, waiting on Level 4 M6...
Oct 24, 2003 | 10:08 PM
Well, I pulled my tranny out in alittle under an hour and a half. Very easy and straight forward. My tranny always had a leak on the front side of the case which I found out was a leaking front main seal. The procedure was very easy, load the car up on some jackstands, drop the rear carrier, tilt it down to the reference point and wala. Removing the pin in the shift lever was a PITA but easy with a small jewelers screwdriver.
I ended up ordering a Level 4 M6 from Rodney, it's with UPS and should be here this weekend. I'll finish up the install monday and be at the track friday getting ready for the world cup finals. :)
Phillip
Oct 24, 2003 | 10:17 PM
Re: Removed trans, waiting on Level 4 M6... (Phil97SVT)
Tranny removal procedure:
1) Lift/jack car up on jackstands 12"
2) Remove center console
3) remove shifter
4) Remove 2 40 hex bolts from shifter to torque tube bolts
5) Remove rear tires
6) remove emergency brake bracket
7) remove ball joints
8) remove brake calipers
9) unbolt shocks
9.5) remove exhaust
10) pop axles
11) unbolt diff from carrier
12) support carrier
13) unbolt carrier
14) support tranny
15) remove rear carrier
16) Remove center support bolts(small X 60 ones)
17) Lower rear end until reference point is aligned
18) Unbolt tranny to torque tube bolts
19) pry apart, slide slowly, once 4" apart knock pin out for shifter linkage
20) remove tranny/diff
Time: 1:30
[Modified by Phil97SVT, 9:18 PM 10/24/2003]
Oct 25, 2003 | 12:04 AM
you duh MAN!! If I ever get to the same track, area, gathering as you Phil, well..... beers on me or whatever you choice of beverage. :cheers:
Lance
Oct 25, 2003 | 12:55 AM
Good work. When are you going to switch to auto?
Oct 25, 2003 | 02:09 AM
St. Jude Donor '08
I'm not brave enough to do it myself yet, but am going with a tranny upgrade also. Good luck to you. :cheers:
Oct 25, 2003 | 02:19 AM
Re: Removed trans, waiting on Level 4 M6... (Noran Raad)
:iagree: :smash: :cheers:
Oct 25, 2003 | 02:30 AM
Great info phil, I have a feeling I'll be doing a writeup on this one of these days. Looks like it's actually pretty simple. :)
Oct 25, 2003 | 08:16 AM
Thanks Phil for the tipl Put it in my how to file.
Oct 25, 2003 | 08:39 AM
CA Events Coordinator
I will be needing to upgrade my trans too.. What does the rebuild actually beef up and how much did it cost? (if you dont mind me asking)
VR :cheers:
Oct 25, 2003 | 09:06 AM
Re: Removed trans, waiting on Level 4 M6... (vetterdstr)
VR :cheers:
Ditto...and how much hp/tq is it rated for?
Oct 25, 2003 | 01:11 PM
I'm a little slow :confused: What is a level 4?
